ok, my friggin SD60I is like famou now, and i JUST took the train out of the box, and i Have NO powen to the front trucks. Im using the 163 PIN decoder, the decoder was stuck to the harness, so i said screw it, and I put it on, but the shell wouldnt close. the harness that was originally on the board I had to cut off, cause the decoder would not lay down properly, could that be the problem? the wires are attached, and looks fine, any help please? im not at home right now, so just tell me what i could do. ill ahve a response/solution from u guys in afew days i hope.
Join the wires from the front truck to those from the rear truck.
what type of wire do i use? its only long enough to go to the trucks, to the board
i have a engine with same problem and coudnt figur it out. can the wire be splice to make it work?
No “power” to the truck or no electrical pick up?
no powr to the truck untl you push it down
I have re-read your post a few times. Frankly between the misspellings, language, etc. I can’t get a clear picture of what your problem really is. If you wrote in a fit of disgust and anger over the situation, I suggest restating the problem.
Bob
