I have 4 of the SD45T-2’s and I am thinking about trying to install a Lok sound decoder in one of them. They have plenty of room in the body for the instalation, I am also looking at the Digitrax SD38-2 decoder, a little cheaper than the Lok sound.
The SD38-2 does not have a turbo, thus if the decoder is correct for the SD38-2, it will not be correct for a SD45T-2. The SD45T-2 were turbocharged.
You may want to consider getting a Walthers P2K U28B for less than $90, and ordering a new V7 chip for it (~$30) with EMD 645 turbo sounds, and using that inside your SD45T-2…
On the prototype, it was not quite “the same guts.” The 20 cylinder prime mover in the SD-45 had a distinctively deeper rumble than the 16 cylinder SD-40 series. It will be interesting to see if any of this comes through the little speakers we are forced to use (e.g., HO scale). Somwhere, I saw the ESU Lok-sound listing that had an SD-45 series with apprpriate horn (Nathan three-chime for the SP). It will be interesting to hear if there are any perceivable differences.
Prior post reply attempt got lost in the ether somewhere. Basic comment is that on the prototype, the 16 cylinder SD-40 series did not have “the same guts” as the 20 cylinder SD-45 series. The deep rumble of those twenty-bangers was quite distinctive on long mountain grades. A listing of ESU LokSound files shows an EMD 645 20-cylinder (SD-45 series) with Nathan three chime–just the ticket for an SP unit. It will be interesting to hear if there is a detectable difference in a model (HO) installation, given the small speakers–not much bass.
