By default Engine sound when track receved voltage.F8 button will trun on and off engine sound.
how can it be programed that engine is quiet upon receving track voltage .and only control by F8.
Thanks Rainbow 24
Thanks Rainbow 24
You can download the ESU user manual from their web site, which will list every CV.
Change the following. Be sure to set the two register CV’s (31 and 32) first …
CV31 = 16, CV32 = 2
CV403 = 16
With this change, you will need to turn F8 ON in order to start the engine. At idle, F8 will put the engine into shut down sequence when turned off. If F8 is turned off while the engine is moving, it will immediately mute the sound.
Mark.
Thanks mark
i cannot promgram cv403 (I’m promgram from a dt400 will not go pass250?)
That’s ok, not all systems can access the higher CV values. Fortunately, ESU provides a workaround …
Example: You wish to programm CV 403 with value 16.
Proceed as follows:
Programm the value of the CV number in hundreds in CV 96. In • this example: CV 96 = 4
Programm the value of the CV number in units and tens in CV 97. • In our example: CV 97 = 03
Programm the CV value in hundreds in CV 98. In our example: • CV 98 = 0
Programm the CV value in untis and tens in CV 99. In our example: • CV 99 = 16
As soon as you have programmed CV 99, the correct value will be transferred into CV 403. Once the programming is finished, CVs 96, 97,98 and 99 will be set back automatically.
Mark.
