Atlas HO RS-1 Diagram
Does anyone have a link or can scan and send me an exploded parts diagram for this Atlas locomotive?
Bear,
I found a number of them on the Atlas website at the link below:
https://shop.atlasrr.com/t-partsdiagrams.aspx
Here’s the direct links to the RS-1. There are two of them listed:
RS-1
RS-1 Japan
Thanks, Tom. I checked the Atlas site before I posted and I assume I was using the wrong search terms.
You’re welcome, Bear. I just googled “atlas+exploded view” and that was one of the first few options.
Bear. hope yours is that sweet running (Japan) Atlas yellow box Kato unit, they are excellent. Only con is the weak walkway pilot and body mount coupler. Heavy load flexes the walkway and allows coupler drop. I replaced with Kadee 30 series box and reinforced under the walkway. #5 box is too large to set in proper distance for buffer plate position.
Bob, it has been a while since I got it, but I don’t think it is the Kato. I bought the undecorated version with DCC. The coupers have been changed out to Kadees, though.
