I know there is description on how to wire an Atlas switch machine to two momentlary on push button switches but I can’t find it so anybody out there have a diagram you could share?
Thanks
Dennis
Thanks
Dennis
Atlas machine contacts = Left, Center/Common, Right.
First push button contacts = A, B.
Second push button contacts = D, E.
Power supply contacts = 1, 2.
Button contacts A & D are wired together and go to power supply contact 1.
Switch machine contact C is wired to power supply contact 2.
Then button contact B goes to switch machine contact L.
Then button contact E goes to switch machine contact R.
Thanks Folks, appreciate the help on the Atlas switch machine wireing instructions!
Dennis
That wiring diagram is not correct. Follow the wiring - soon as you press one of the button, you short the power supply ! This is how it should look …
Mark.
I belive this diagram has some problems. The black common wire should NOT go to the push buttons. As shown when one presses either button there is a short circuit. Not to mention that both solenoids would be on all the time. The only time common power should go to a push button is to power the lights if they are illuminated.
Replace the black common wire on the push buttons with the red power wire from the supply (instead of putting them on the load side) and all will be well.
you’re right
thanks
… Which is exactly as my diagram shows …
Mark.
