This review is on Bachmann’s Standard line DC FT-A diesel.[:D]
Bachmann’s FT is obviously not the most realistic one on the market, with the main problem being it’s on a standard F-unit frame instead of an FT frame. The shell is the one originally developed in the 70s for both Bachmann and AHM, which was quickly dropped from AHM’s line of diesels. It has the basic look of an FT-A, but the detail is only average, even for the 70s. Most of the larger grab irons are molded on, but they’re very fine and nearly invisible if you aren’t looking for them. Besides that, the shell is pretty lacking in detail, with only the major things molded on, like roof and side ventilation, windows, a single headlight, marker lights, and doors. Most of the steps and ladders are molded on, but the rear ladders are missing. The paint is actually pretty good, with sharp lines all around, except for a little fuzz around the pin-striping. The lettering is sharp and looks very good, but the yellow striping on the front shows through the Santa Fe logo on the front a little. The trucks are very well detailed, but they’re the basic ones used on almost all of Bachmann’s 4-axle diesels, and don’t have the large bearing caps found on the prototypes.
The FT comes with an excellent drive mechanism, with all wheel drive and electrical pickup, a heavy metal frame, quiet gearing, and an excellent 5-pole skewed armature motor, which is wrapped in foam to reduce noise. It ran very smoothly, quietly and steadily at all speeds, reaching
