Bachmann Porter Bash
Well All,
As if I don’t have enough projects in the works.
Stuffed back in a dark corner of the hobby closet was a Bachmann Porter bash I started a few years ago.
Utilizing the updated Porter (new drive unit, metal rods, etc.) and some Lionel 0-6-0 leftovers, a USA archbar truck, 3/4 inch diameter wheels and some styrene, a Forney was in the making. The smoke stack is a combo of the Lionel fluted stack and brass tubing.
I plan on changing out the headlamp, however, haven’t decided which way to go. I may use a barrel style Ozark lamp or oil burner. Haven’t placed either one on the loco, Sooooooo.
The tender will be extended and also an air tank added behind the tender box (similar to the bogies and other Colorado Narrow Gauge engines). The cab is reminisant of the Bogie, so, I guess its going into the GG&BP RR motive pool although a very diminuative 1:20.3 model. I do remember seeing a very small Forney at the Forney Transportaion Museum in Denver a few years ago, however, this one is a “SLIGHT” deparature from that engine. Maybe not any prototype Forneys similar to this bash, but, HEY,
ITS MY BASH AND I’LL BASH IF I WANT TO!!! YOU WOULD BA***O IF IT HAPPENED TO YOU! LOL
You guys are encouragable. Wait 'till you see photos of Sunday’s chopping and cutting.
The motor is vertical, moved the cylinder chest back 3/8 of an inch, modified the cylinder covers, cut off the boiler (superstucture)to add a larger diameter, heightened the cab, enlarged the cab door and so on.
[img]http://1stclass.mylargescale.com/railgeek/F
I’m definitely watching this one!
Matthew [bow]
Been following along, looks like a fun one
These little porters are alot of fun to work with; nice design. With the metal drive rods and rugged motor mount, lots of options.
I’m contemplating buying another 2 down the road, shortening the distance between the drivers and bashing a small 2-4-4-2.
Thanks,
Marc[8D][8D]
Hi mgast
I will be watching this one.
Given the cab shape go with the big old fashioned oil lamp,
that IMHO will keep the believability factor high
[2c]
regards John
John,
I have several of the Hartland (old Delton) lamps. I haven’t placed it on the engine for comparision.
It might be a little too large. Who knows.
I’ll post a photo of it and let me know what you think.
Thanks,
Marc
Neat project! I am going to keep tabs on this one and watch your progress!
Hello mgast
Thanks for the view of the project - it looks fine.
I also have a rather battered Bachmann 0-4-0 Porter locomotive from a start set, just collecting dust on a shelf - and feel tempted to do some kitbashing to it - however the underframe seems to be well worn, making it a terrible runner. Does anyone know if it is possible to obtain a metal underframe from anywhere.
Thaks for any help
Peter-DK
Hi there you ole bashers you!
I am just getting started both in the rhelm of bashing, and on deciding what to do with the three Bachman Portors I’ve gathered.
I appreciate your ideas, and look forward to pictures and comments from those of you whom have bashed this wonderful little loco locomotive!
Bob from Oregon
We could do a Porter Bash Challenge here.
Let’s go for it!!!
Marc
