BACHMANN SHAY SMOKE UNIT
HAS ANY ONE REPLACED THE SMOKE UNIT IN BACHMANN THE SHAY WITH A TURBO FAN UNIT , ARISTO-CRAFT OR TRAIN AMERICA STUDIOS NEW TURBO HUFF AND BUFF UNIT . JUST PURCHASED A SPECTRUM SHAY AND WOULD LIKE TO ADD A FAN DRIVEN SMOKE UNIT BUT NEED HELP IN DOING IT RIGHT
THANKS GUYS , BRAD MOORE
Hi Brad,
Can’t say I’ve done that, but there will be someone who has! In the meantime a big hello to another recruit.[#welcome]
Cheers,
Kim
[tup]
THANK’S KIM FOR THE REPLY AND THE WELCOME , SURE HOPE YOUR RIGHT AND I WILL GET SOME HELP ON THIS . HAVE A LOT TO LEARN , DON’T WANT TO SCREW IT UP .
THANKS AGAIN BRAD
Hi[#welcome][#welcome]
The Bachman Smoke units Stink!!![:(!][:(!][:(!] The smoke unit for my Bachman Mogul, the smoke wont even come out of the stack, it just builds a white clowd inside the stack!
Just make sure you idenitfy space first.
The smokebox is kind of narrow on the Shay.
You also need to think about upgraded trucks, as the original pickups do not cotton to any higher current draw than they have, and even then they might go POOF!
There is a voltage regulator board screwed to the ront of the weight, usually accessed by lifting up and sliding back the sand dome. Make sure if the smoke you use needs track power you remove this board and hard-wire to the flicker board.
TOC
Plug that Bman loco into the wall socket [:P][:D] I gaurentee it will smoke more than you ever saw, but then again, it won’t ever run again [xx(] Oh well [8)] Just kidding [;)]
