Backdrop help needed
Hello, I would like to have your advice regarding putting up a backdrop on my layout. As you can see, 3 sides are open so should I put a backdrop on all 3 sides or just one?
I’m modeling freelance, transition era.
Any comments or suggestions are welcome.
Thank you and have a nice day [;)]
Uploaded with ImageShack.us
Nice looking layout. [tup]
At a minimum I would start by painting the walls a sky blue. You can start with 1 backdrop and just paint clouds on the others. Ultimately I’d put one wherever the layout comes close to a wall.
Good Luck
YES, I agree on both points ,nice …Jerry
My layout is bolted to the wall on three sides. I painted the walls sky blue then put up a set of printed backdrops I got from Busch. The layout is now surrounded by a hilly forest scene on three sides with only the operators area being open. The background adds a 3D punch to the photos.
Those Busch backdrops are really a winner when it comes to a 3D effect. I have used them on two different layouts I had built some years ago. Unfortunately, they have a “European” look to them, which may not be suitable for the region you may model.
The easiest way is, as mentioned, to pay the walls sky blue - but what is sky blue? I prefer a light gray - very light gray, as we don´t see a clear blue sky many times in the region where I live.
Hello, I would like to thank you all for the suggestions and compliments, I still have a long way to go and this is my first layout.
The more I read topics on this forum and also articles in MR, I say to mysel, gee I should of done it this way instead of the way I did it; I guess it’s called the learning process…
The original reason why I wrote this topic is that since my layout is open on 3 sides, should I build backdrop walls on the left and right sides of the layout or should I leave them open? Layout size is 9’ x 12’.
Many people simply put the background on 1-2 feet sheet styrene and attach it to the sides of the layout. That allows you to still reach over for maintenance and still give you a trackside scenic view.
Consider adding a two-layered backdrop. The sky could just be the walls of the room, painted pale blue, perhaps with clouds added if you like. But then, as a separate panel, add everything up to the horizon, i.e. everything that isn’t sky. This panel could attach to the layout sides, and it would be low enough to see/reach over from outside the layout. It might even be removable, and if generic enough it could be swapped to the opposite side of the benchwork for taking photos from alternate angles. You could use photographic backdrops for this, just mount them to a rugged backing material and carefully cut them out right at the sky’s edge.
Hello, I would like to thank you for the additional ideas.
I think I’ll make smaller removable backdrop pannels for both left and right sides, and for the backwall, paint a sky and clouds then adding photo backdrop to blend in with the sky.
So you see all of your ideas are very usefull, and as they say…2 brains are better than 1.
Have a nice day [;)]
Good Luck with it and don’t forget to post pics of the result.
One piece of advice I’d offer on picking the shade of blue for your sky is to paint a small patch of the wall first, let it dry, then see what it looks like under the actual layout lighting conditions. I thought I had the perfect shade, but when I saw it under my florescent lights, it was way too pale. I re-painted with a blue that was several shades darker, and it looks much better.
Just automatically going with a darker blue than you think may not work either, as your lights may not be the same as mine, or in the same position as mine. That’s why doing an actual test is better.
Good luck!
Hello again, thanks O’Dave for the additionnal infos on the blue sky paint, I’ll be sure to post results once the backdrop will be completed.
Hi Serge.
Judging by the quality of what you have done so far, you have more than enough skill to put up a seamless backdrop made out of masonite. I did it, so that means it can’t be that hard to do.[:)]
I attached mine with 10/32 machine screws and “t-nuts” to the benchwork. Using a drill to undo the screws, it will come off in a flash if need be.
Filling the cracks was easy using drywall compound and they are invisible even up close. Just take your time.
Brent
Scribbet,
Here’s an option to look at:
http://www.sceniking.com/CatHO.htm
I’m looking at getting C003, which is used here http://www.sceniking.com/SIA.htm (scroll down to the one labeled “Prince Edward Island”
Hello, thanks a lot Brent for posting pics of your backdrop it looks very nice; I’m a visual person so for me a picture is worth a thousand words…
I think that adding a photo backdrop by SceniKing (thanks Antonio) and blending it in, would complete it beautifully.
Thanks a lot guys [tup]
Nice layout! My 2 cents - I understand the benefits of having the layout like an island so you can walk around the outside, but personally if I decided on that kind of layout, I wouldn’t have a backdrop. Alternatively, since it looks like you could reach from the center to the back of the layout, could you push the layout back against one or two walls - ie: against one so you could backdrop one side, or into a corner so you could backdrop two sides?
I just think backdrops on an island layout take away the viewing benefits. Thoughts?
Hello Aralai, being able to acces my layout on 3 sides is interesting and I thank you for bringing up that perspective.
I will certainly analyse all of your suggestions and see on the premises what will visually look the best.
I cannot move the layout against left wall because I have to leave access (min.3 ft wide) to the electrical pannel.
Hi Serge.
If your layout is not against a wall I tend to agree with Aralai. My last layout was 5’ x 10’ and I could walk all around it. I enjoyed running and watching the trains from different vantage points around the layout. That being said, sitting in the middle of things with a backdrop shielding you from the outside world can be nice too. Keep us posted of your progress. I like what you have done so far.[:)]
Brent
I can’t really tell from the photo, but is one side against the wall? If so, then I would tend to backdrop that side, and possibly the side where the industry with the blank chimney is. That might be a good compromise but still leave much of the layout open for viewing.
Hello Brent, thank you for the compliments, it’s my first layout so I really don’t have a precise plan to follow since it’s freelanced, the only part of the layout that’s aginst a wall is the back, both left and right sides are open so that would be interesting for viewing as Aralai mentionned it.
Thank you Aralai and Brent for your comments they are greatly appreciated.
