Ballast or scenery first?
Just wondering what others do first. Do you ballast your track or do most of your scenery like grass, roads and such first?
I’m at the point, finally, where I’m going to start ballasting. Or ground foam. [:^)]
If it’s next to the track, I do grass and roads first. Grass on the mainline ballast just isn’t right.
I’ve done/do it both ways,didn’t really see a difference
Guess it depends on what you feel like doing at the time
I ballested first, then scenery, than touched up any ballast work along the outside of track.
I don’t think it makes much difference. I liked the wide open area to work with the ballast, and the method I used to secure it, and not have to work around the scenery.
Mike.
Like Uncle Butch, I have done it both ways. I’m resolved that it depends on what you want it to look like once you’ve invested the patience and skills at your disposal. I don’t mind ‘grass’ showing up here and there on the apron of the ballast, but not on a main line between the rails. I also don’t mind the ballast, even at the extremeties, looking incursion-free as if it’s a new application covering the old. But, I can make both orders of application look the same if I want them to.
I do ballast last. I think it’s because I really don’t enjoy it.
I work in small sections, a few square feet or less at a time.
I use, for the most part, plaster-on-screen landforms, so that part of the scenery has to go in first - otherwise, a lot of ballast and white glue would end up on the floor of the layout room.
Once that’s in place, I add ballast, although in some places, the lineside grass and weeds are done at the same time, as a lot of excess glue seeps out from the base of the ballast - no point in letting it go to waste.
Here’s an example of that, where the foregound has yet to be finished…
You’ll also want to test all of your newly-ballasted track before adding scenery, as trees and structures can often get in the way if you have to do repairs to the track or turnouts.
Another angle from which this can be approached, is to consider that there’s likely nothing that you will do to your layout that will give you as much “bang-for-your-buck” as painting the rails and adding ballast, both simple jobs.
Ahh . . . saving the green beans for last because they’re your favorite?
But seriously folks, I’ve done it both ways, or several ways. Over the years the criteria has evolved into ‘do the messiest stuff first’.
Right now I’m doing landforms, and that involves foam and/or lightweight sheetrock mud, and that stuff is messy and needs to be finished and vacuumed before getting to other chores. But, there were a few areas that needed to be ballasted first: namely the approaches to tunnels and other areas that would be hard to reach or awkward to work on after scenicking. But even then some minimal scenicking needed to be done (such as trackside ditches) and the ground needed to be painted mud/dirt grayish brown before starting ballasting.
So the answer is: it all depends. Hope this helps making a decision. [:D]
Robert
I do ballast last. That way I don’t get plaster and other junk on the track/ballast while doing other work. I also don’t glue the ballst down for a few weeks. If I don’t like the way it came out, it’s easier to change.
Ballast last cause that’s how it looks in real life, which is what we are trying to imitate.
For me it is easier to bring the scenery up to the groomed ballast rather than the opposite of creating a ballast line in vegetation.
As usual there isjust no one rightway of doing things. it’s a personal preference;
Just My Worth
Bob
I completed ballasting & ground cover last year on the current HO layout. I ballasted and applied ground cover “both ways”, and either can work. That said, if you can carefully apply the ballast, I would do it after the ground cover is in place. After all, that is what happened with the prototype.
I have done it both ways, but a problem that I have encountered when doing the ground cover first and the ballast last is stray ballast in the ground cover.
In part, that is due to the light weight of the Woodland Scenics ballast. It easily bounces around. If you ballast with real rock, that may not be a problem.
I am not hung up on who came first, ground or ballast. If this is important, then a case can be made to install your ground scenery on the entire layout before any track is laid, befor and roadbed is installed, before any bridge is installed, and before any balllast is installed, ad nauseum
I prefer to ballast first and have not done it any other way.
LOL
Hey, that is pretty much the way that things were in 1830 before the first railroad was built in the United States.
Like all old industrial areas I can hardly call what I use ballast but,it goes down first.
I do the ballast after the basic scenery inclusive level crossings are done but before the ground cover (grass etc.) is applied. I think ballast stones riding on top of vertical aligned static grass looks odd.
I did my ballast on my modules after static grass. It took quite a bit of effort to vacuum out all the stray ballast floating in the static grass.
That being said, it was worth it for that well maintained mainline appearance. For say a logging railroad, the answer to the question, “which is first ballast or scenery?”, is likely yes.
Thank you all for your responces! I am totally convinced to put the ballast down first. Or wait, no, put the scenery down first.
I guess it’s basically whatever your heart desires.
So it’s settled. Ballast first by tunnels, bridges and yards. and maybe the rest of the layout while I’m at it [%-)], and then the ground foam and dirt. Maybe[8D]
May I back up Richhotrain’s comments… When using Woodland Scenics ballast, I would advise doing it first. It is so light and “bouncy” and can go all over the place. Nothing like seeing a greywhite rock here and there in your lush fields.
True stone ballast (i.e. Arizona, etc.) works very well applied after the ground cover is down.
