Hi Everyone - a train noob here, so forgive my basic questions. My father was interested in mainly HO scale trains. When cleaning out my Mom’s basement, I found his HO trains, but also another box with a much larger scale train (O or S). After ‘Googling’ this weekend, I believe I have identified it as a set with a Marx 999 loco (fourth variation: no Marx logo and a solid pilot with rivets but with no horizontal bars). I’m trying to find out generally what year this may be from (all of the cars are metal, no plastic, there is no box, and all of the swiches are manual turning/no electric) and more importantly, since the only component missing is the transformer, what transformer would be correct for this set (wattage, style, etc.). I ultimately want to get it running to give to my son. Thanks in advance for any help you can provide.
Any Lionel, Marx, or American Flyer 40 watts or more transformer will work. Those sets usually came with a 50 watt model:
A 90 watt Lionel 1033 or 1044 would be ideal and give you some operating flexibility & options.
Awesome! Thanks, ADCX Rob!
Marx trains like the 999 are very robust. Many of the Marx I’ve repaired only needed cleaning and a lube. Good luck with your repair.
Jim
I actually found 2 transformers in a box with HO stuff. One might be a Marx (its labelled 7-15 volts, but only seems to put out 12.5 max) and the other is a Lionel which puts out about the same. The engine seems to be postwar based on the center pickup.
Transformers and Pickup
Either one will work. The red handle is a 50 watts Marx, the other a 35 watts Lionel.
TY!
I’m curious if there is any way to narrow down the year of production. Using these pages as guides and understanding production started in '50 or '51, but I have a post-war, flush rivet, no logo version, maybe the closest I’ll ever get is '46-'53?
Relative to what year this set was produced, the below is background on the Marx 999 engine from a different thread. If you describe the cars (road name, number, color) that came with this set it might be possible to come up with a closer guess than late 40’s or early 50’s. While sets with a 999 engine generally don’t command a lot of money (there are exceptions yours is not one of them), its real value is in its history.
Papa D
The 999 was Marx’s first die-cast shell. It was produced in limited quantities in ’41 & ’42 and again after the war from ’46 to ‘54. The only pre-war 999 ad I’ve been able to find is from the Spiegel ’42 Christmas catalog. Note that shows an open cowcatcher.
After the war, the Sears ’46 Christmas catalog shows a 999 also with an open spoke cowcatcher.
The open spoke cowcatcher was reportedly easily broken. Since Marx’s philosophy was to made low cost but rugged toys, this design was quickly changed to a solid spoke cowcatcher and then probably to save a few pennies to a solid cowcatcher as shown in this Sears ’47 Christmas catalog ad.
The 999 last appeared in the Sea
Papa
Neat information!!!
Jim
[#welcome] aboard!
Further to Papa D’s post, check out this site that has Sears and other Christmas Wishbooks: http://www.wishbookweb.com/the-catalogs/
Despite her appearance, this one can still hold her own with the best of them
Thank you for the great information.
Last evening I tried to get the loco moving, but unfortunately, it would not move under its own power. All I got was some buzzing/humming from inside and some sparks at the rails. I can rotate the assembly by hand, although it seems harder than I would think it should be…like there is way too much mass to get moving (probably why the old tired motor can’t do it). Maybe its binding internally or something although it doesn’t ‘grind’ or anything.
Could this be an indication of bad brushes or seized bearings (if applicable)? or something?..or maybe just 60 years of ‘gunk’ and some rust?
I haven’t had any time to do anything more to the loco, but am going to get some Goo-Gone and some 3-in-1 lightweight oil tonight.
Any other suggestions?
Thank you! The front shot you provided is the pilot I have (solid, no slots, rivets, no horizontal bars). Please see photo attached of the other cars.
Thank yhou in advance.
From the Sears catalogs, possibly a '46 or '47?
You’re having the same problem posting photos that many others also have. It might be easier for you to just give a verbal description of the cars that came with this engine, ie road name & number, number of wheels, and colors.
