Bearings Question
Are any surviving large steam locomotives besides 4449 has friction bearings on loco and tender axles
Don’t call them ‘friction’ - they are ‘plain’ bearings. Roller bearings are ‘antifriction’ but that only makes ‘friction’ the opposite if you are a Timken salesman.
The three ‘early’ surviving Reading T1s have some plain bearings, whereas 2124 is ‘all roller’.
I think I see where SPer’s coming from, I’ve heard the term “friction bearing” myself, scratched my head over it too, but I believe it refers only to the old “axle rotating in oil-soaked waste” brass/bronze with babbit metal lining bearings used on freight and passenger cars before roller bearings came into common use.
Here is the story in brief. (Well, relative brief.) The bearings that use brasses, whether lined or not, fully circumferential or not, are all ‘plain bearings’ (or, if you want to be technical and accused of pedantry, ‘hydrodynamic bearings’) regardless of the method that is used to lubricate them (wicks vs. pads, oil vs. grease, etc.)
The actual ‘bearing’ in all of them is a comparatively thin film of lubricant, usually oil or the oil component of a grease, compressed to a wedge and then to a pressurized film between the face of the brass and the steel axle journal, holding them apart. There are very good reasons why the crown and liners are made of brass, bronze, or white metal: any asperities in the lubricant that might break the film and cause scratching between two hard faces will instead embed in the softer material to the point the film forms over them. This is a different mechanism from slow-speed bearings, in clocks for example, where this process only turns the softer material into a comparatively effective lap that preferentially eats the journal surfaces.
An important thing to remember is that once the hydrodynamic film has formed and come up in temperature to reasonable viscosity, the plain bearing generally has less resistance to motion than a roller or ball bearing of equivalent carrying capacity, and of course is less prone to damage by spalling or breaking should any dirt get into the tribology (or shock or jerk be communicated to the essentially line contacts between rollers and races). The catch, of course – one of the reasons roller bearings with M942 lube became standard on interchange cars – is that the lube film has to remain full and intact. Hairs from the waste or pad, or inadequate oil, will rapidly cause the bearing surface to go into thermal runaway with the result being an infamous hotbox (or worse).
Now, it was recognized no later than the 1840s that using rolling elements between the bearing an
Expanding vocabulary.
https://ia801300.us.archive.org/BookReader/BookReaderImages.php?zip=/29/items/ENGINEERINGTRIBOLOGY/ENGINEERING%20TRIBOLOGY_jp2.zip&file=ENGINEERING%20TRIBOLOGY_jp2/ENGINEERING%20TRIBOLOGY_0026.jp2&scale=2&rotate=0
https://archive.org/details/ENGINEERINGTRIBOLOGY
Hot stuff Wanswheel! Looks like you’re back with us!
I also, have heard and used “friction bearing” for the old, non-roller bearing axles. And I will probably continue to use the term. So it’s not correct. Many things, especially in railroading, use simplified or archaic terms. The thing is, those that use the stuff in the field know what a person is talking about.
Take “triple valve” for instance. The last true triple valve was outlawed years ago. The correct term is “control valve”. I’m sure in the higher and more technical echelons of railroading, control valve is used. Out in the field, however, you’ll hear “triple valve” from the likes of train crews, dispatchers, and even carmen.
Jeff
Who knows how things get the names the do, and how they stick?
Anyone remember the old liquid-process copiers from 30+ years ago? The development process involved two components, developer and toner. When the dry-process copiers were invented one of those components was eliminated, specifically the toner. However, the name “toner” stuck to the dry powder that’s loaded into todays machines, which should be called developer. Makes no sense, but that’s the way it is.
Take it from one in the trade.
A failed and/or overheated roller bearing is still called a “hot box”, even though it is not square or rectangular in shape. And though their official name is “Wayside Inspection System” everyone still calls them “hot box detectors”.
Names stick around, several of our yards still have a “steam track” or “icehouse lead” even though it’s been decades since everything ice or steam related was removed.
I’ve always called them “plain bearings”, but have heard the term “friction bearing” used too.
And I’m sure many of us know, or have known, members of the World War Two generation who still call refridgerators “iceboxes.”
I really enjoyed both Jeff’s and dude’s comments.
Before the Calgary Herald became the last user of an industrial lead a couple of years ago, and the lead removed, the switch was always referred to on the radio as “Titian” a station in the ETT’s that disappeared back in the 60’s.
In our house, growing up, there were any number of expresions my Dad used from work. For instance, when he wanted to tell us when to be ready to drive one of us to the many places dads have to drive their kids, we were told the ride was “supplied for 8:15”.
Traditions on the railway work the other way as well. Alyth was opened in 1899 to replace the original “Calgary” yard, and caboose maintainance was moved as well. What had been the original Caboose Track always kept that name. During the annual slowdown before the fall grain rush would start, spare cabooses would be moved from Alyth up to the Caboose Track, but what was even more amazing, is that according to various sources, there were cabooses parked on that track every year unitil caboose use ended in 1990. Apparently, that track was never used for anything else, it was a violation of an unwritten rule, or a law of nature, or something.
Bruce
According to Xerox patent history, when copy technology went from wet to dry process the “toner” was the colored powder component of the “developer” (see the Walkup patent, 2638416, and Lehman 3336905) and it is not entirely surprising to me that when separate carrier was no longer needed in a two-part developer, and ‘toner’ was the only material needed to develop the electrostatic image prior to fixing, the industry distinguished it from earlier developer. I will certainly grant you that, semantically and historically, ‘developer’ is a better word for what the stuff does.
Our copier will display “low on Toner” and “replace Toner cartridge”.
On a digital LCD screen no doubt.
Does it have a touchscreen?
Oh yes, multiple digital screens and its all touch.
CN buys those giant new Xerox machines for all the yard offices, with touchscreens and all the bells & whistles.
They usually last about 4-5 months before being replaced, due to the sheer amount of paper we go through. One of the service guys said that in a month one of CN’s machines will go through the same amount of paper a typical office one would see in a year.
Ours are on a 2 year lease and get very heavy use. The one in the Mine School building supports 4 different programs each with many multiple courses and a half dozen profs, plus the students.
It does everything of course and rumour has it it sings God Save The Queen at sunrise. I also believe it tracks my every movement.
Now this is true…just this past week I navigated onto a screen I had never seen or used before, trying to fiqure it out and there in the corner along the bottom is my name! Blurted out “whaaaaat” out loud. We have a code for departments to log in but not by individual name. How did it know who I was! That thing is watching and recording my every move.
Our resident specialist on the Forum is Firelock…I imagine he has seen it all and knows whats up.
How it got your name I’m not sure, unless you’ve got a resident IT person who input it while he was setting up the machine for the different departments. This is a feature a lot of machines have now for keeping track of “who’s doing what,” that is, checking that your copying/printing is being done for business purposes and not for “extra-curricular” stuff like printing car wash flyers, church bulletins, yard sale notices, and so forth.
Singing “God Save The Queen” in the morning when no-one’s looking? I doubt it. More than likely it’s singing “Kimigayo” at it’s first glimpse of “The Rising Sun.”
https://www.youtube.com/watch?v=S2Vanclvh3Q
Machine getting a lot more use than anyone thought? No surprise to me. It’s a common mistake many businesses and schools make when purchasing (or leasing) a copier. Underestimating how much use the box is going to get, then overestimating what it’s capable of handling. Only about 75% of the places I go to seem to get it right.
And those “smart phone” type touch screens? None of my customers seem to like them very much. My colleagues and I usually set them up for what’s called “Classic” choices, i.e. make the “Classic” selection and the traditional copier-printer-scanner-fax menus folks are used to show up on the screen. I think they’re pushing the technology just a little too fast for the end users on these things.
And a “paperless society?” Forget it! Not going to happen in our lifetime, not from what I see.
Yes thank you Firelock. As long as Governments, Lawyers and everything else is still around we will never go paperless. A few hot shot young profs touted their paperless offices and classrooms to disasterous results. Of course when they leave the school or their contract is up over the summer IT comes in and wipes their 'puter clean and then there is bupkis for the next guy. It’s so dumb. They do it in the belief they are saving the forests or something and thus think they are cool.
You are right about IT…thats a black hole, information goes in, nothing comes out and those guys are the ‘men in black’. No sense of humour either. Yeesh. We have 4 full time plus a Director. They grunt a lot.
I officially complained once at a meeting with the big bosses that those guys could at least say “hello” or “good day”. It worked!
Since my laptop talks to the copier I suspect those 2 conspire together, along with IT.
Hey anyone remember carbon paper for typewriters in order to make copies as you typed? At least it’s not digital, on line or being recorded as you go.
I sure do, we still use it at work. The rules state you have to have multiple copies of clearances and some other authorities, and they have yet to put photocopiers or fax machines in the locomotives.
