I think you have identified the two that are the most common.
HO stands for half-O Scale. So, one of the âbiggestâ advantages of HO, is that it only takes half as much room. So, you will get a lot more action, scenery, etc with a given amount of space if you do HO instead of O-Scale. Generally, O-Scale is more expensive than HO. Once again, cause it is bigger. As far as realism, I think HO has more scale offerings.
Lionel holds it value really well. Just look at some of the Ebay adds with old locos and such. Plus, if you wife is into Dept56 or similar size ceramic houses, then you could combine your hobbies. The 3rd rail for O-Scale makes wiring a little easier when it comes to reversing loops or wyes.
The best information on the Lionel or other O-Scale trains would come from the âClassic Trainsâ or the âToy Trainâ sections of the forums. Not trying to insult the O-Scale trains, but those are the 2 magazines that cover them, so you will find a lot more discussion on them there.
donât buy into the thinking that O scale is more expensive than HO. O scale equipment is 4 times the size as HO, therefor, you can only get 1/4 the amount of stuff in the same space. even it it costs 4 times as much as HO, you wonât spend any more money when you are done.
O scale does not necessarily mean a 3rd rail or more money, check out the bachman (and other) ON30 equipment, comparable prices to HO. Realism and detail are one advantage to O scale, it depends on your interest level, ie, HO has the most variety available where as O scale is more of a modelers scale, despite the size of the equipment you can produce a very nice O scale layout in a small space, plus its easier to work with due to the size.
HO is the most popular and âcommerciallyâ versatile, however for a âwild westâ theme I would seriously consider O scale and some of the ON30 equipment.
Thats kinda the way I think, if you want lots of trains, options and ready to roll stuff HO has it, if you like to build stuff and want lots of detail and realism go with O scale, but before you decide on either make sure you have a good look at whats available in both and what you really want to achieve and what others have done.
Hardcash, these fellows are giving you good ideas and advice if you were to ask me. There are several factors to think about in terms of how enjoyable the final product is to you:
Availability
Visibility
Ease of handling
Overall costs
Quality and reliabilty
If your aim is pleasure, then you would want to invest a great deal in high quality and readily available items that complete your set-up, your layout. But even so, you need to be able to manipulate them with your aging hands, and your aging eyes should be able to reveal them to you for several more years in all their glory. Your goal is appreciation and fun, but if you canât handle or see what you want to enjoy, or if it has lots of mechanical issues, your enjoyment will suffer nearly catastrophically.
As we age, and as you must already know, we need more light to see. If lighting increments will be problematic after a while, then give yourself a buffer at the outset with models that are easily seen. That will necessarily be O gauge or O scale (they are not the same thing). As Harold and others have suggested, you can get the best of both worlds by using HO track to run the scale equivalent of narrow gauge western engines such as on the Denver & Rio Grande Western or the Durango & SilvertonâŚtwo of the most modeled roads there ever were. For convenience you can run O scale engines on HO track. My own Christmas train set is a Bachmann On30 set, meaning that it is a full-sized O scale engine that in real life was meant to operate on 30" gauge. When we move from one scale to another in the model world, HO track fits the 30" narrow gauge requirement very nicely, if not completely accurately to scaleâŚhence my use of the word âconvenienceâ. We try to keep it simple.
If by the Old West you mean 1870âs to 1880âs there isnât much available in either scale. A lot of the narrow gauge dates from around 1900 onward. There is some standard gauge in HO. If you have the room for it, some of Bachmannâs Large Scale narrow gauge models (1:20.3 scale) date to that period, notably their 4-4-0 and 2-6-0.
It also depends on what you want to do with the models. Do you want to build models or buy everything ready to run. Is this basically a display layout where the trains provide some action in an Old West diorama or do you want to engage in operating the layout like the prototype did.
In general large scales favor building because the pieces are large. They also favor display running because the large trains have more âpresenceâ as they run. Smaller scales favor more of a scenic setting for the trains, longer trains and having more railroad - that is more towns, yards, etc - which helps make operating more interesting.
O is the hands down winner. Itâs large, rugged, available, and way cooler than HO. Donât buy into the âexpensiveâ myth, itâs a lie that O cost more. You can buy O at close out sales, yard sales, 2nd hand shops etc. O scale is bomb proof, if you drop it, if the dog grabs it and runs, itâs OK, wipe it off and continue. O scale is orders of magnitude easier to repair, itâs bigger so itâs easier to see, and you need fewer tools. O scale you leave in your will to grandkids. O scale takes up only slightly more room than HO, so no need to worry about that.
Now to respond to your questions directly without all the pontification and assuming youâre talking about model (not toy) trains: HO scale is about ten times more popular (number of modelers) and four times more versatile (takes about one-fourth the space and has four-plus-plus-plus more products available) than O scale.
Now, back to my cave to avoid thrown objects from minority scalers.
I will enjoy HO scale for a few years yet in my home. I believe that HO scale offers the best oppertunity.
However, old style Lionel and similar O gauge are bullet proof and require more basic plan for the smaller space than does HO scale.
With that in mind, I may be moving up into O gauge with advancing years. I already have started the planning for a simple out and back track plan plus the rolling stock, engine and caboose necessary to make it happen. Train length will be 5 to 8 cars and a few more for staging.
In HO you can find yourself with dozens of engines and hundreds of rolling stock.
The real question comes down to availible budget. That shooting you like to do will probably see a bit of a slow down in ammo supply once you start buying stuff for trains.
Take care to avoid certain O gauge stuff that appear to be a bit⌠over done. I started off in O-27 and moved into O gauge via Lionel post war as a child and recently looked over the offerings availible in O gauge in two hobby shops. The pricing for O gauge will be more expensive than HO. The other issue is space. What I can do HO in that room, I would have to make a more simple plan that still operates in O gauge.
I doubt by then there will be too much trouble doing that in the future.
I think I avoid N scale because if I was to pick something up in N it will get crushed.
Maybe the older O scale stuff was âbombproofâ as has been stated above. Also be wary of the difference between O scale and O guageâŚ
I certainly wouldnt want my dog picking up and running with the following items, yes O scale is bigger and sturdier but bachmans later offerings are loaded with detail and still delicate.
Check out micromark.com and others for sale prices, as above the baldwin is $136 and the mogul is $84, an On30 porter for around $50⌠I really dont see how it is more expensive than HO and these prices can still be beaten. I know I for one would much rather put DCC and sound into an O SCALE loco than a HO one. (although of course there are options to buy the units already installed.)
Expense, space and time involved are all relative to what you want to achieve, until you are absolutely sure of that, read, investigate and learn everything you can before jumping in and making the all to familiar expensive mistakes.
I think the all-important question is how realistic/accurate/true to your chosen time period do you want to be? Will it be Civil War era, or 1880s? Or does it matter, as long as your models give an impression of the Old West, even though they be models of too recent prototypes?
In both scale O and HO, the suppliers of true 19th Century models tend to be very small firms that donât advertise in Model Railroader - but they do exist. Some focus on Civil War era, others focus on later. The Yahoo EarlyRail group is a great source of information.
SMR makes beautiful locomotives in scale O and O gauge, but at high prices. In HO, the 19th Century models tend to have cheap drive mechanisms because of the price point of the models. OTOH, there are many wood and resin car kits available in HO; not so many in O. In HO, there is often difficulty in making good locomotive mechanisms and very fine scale details due to the tiny size of the prototypes when compared with the behemoths that came out in the 20th Century.
If you are willing to compromise, there is a fair amount of RTR HO equipment modeled after very early 20th Century. And Lionel and MTH make some 3 rail locomotives and rolling stock - but again accuracy to 19th Century varies widely.
Which brings up the other benefit of the tiny size of the prototypes - 19th Century O can fit in nearly the same space as a 1950s (or later) HO layout. Cars are half as long as their 1970s brethren.
Finally, as others have said, narrow gauge is an option. Colorado narrow gauge got its start in the late 1870s. But by 1900, narrow gauge was shriveling in the prototype world - although one would never know it from the model world, which focuses on 1920-1950 narrow gauge. Itâs easier to build models of better documented later equipment for those fastidious narrow gaugers!
I model in HO because of the greater availability of items I can buy that are not only RTR, but also detail parts and kits of the type I want to feature on my layout.
This is just me thinking out loud, OK?
If I was starting out like you at 64 and with an already well developed involement in another hobby or interest that will influence or be part of model railroading, then I would opt for O.
Depending on where in the Olâ West you see your model railroad running there are some modeling advantages in choosing O or even narrow guage O. You have bigger models to use and I belive that this is important as we get older. There is a lot of information in books and magazines for you to reference regarding the very realistic level of detailing old style wooden buildings that charaterised what comes to my mind as being, the cowboy era Old West. Your trains will be be made-up of just a few cars and a caboose running behind a locomotive so available space using this larger scale my not be a hindering factor at all. If you model a desert terrain then your scenery will be a lot less âfussyâ than if you modeled scenery that required old wooden trestle bridges and large rocky mountains. With a desert there can be some pretty dramatic scenes with in a scene such as a train or bank robbery or a gun fight in progress or some modeling opportinities around a water filling or fuel(wood) stop. Vegetation will not be abundent but can be interesting and well detailed
Authentic detailing opportunities are one of the reas
Tell us about what youâd like to to for building your layout.
Do you have a nice garden outback in which you might want to build your layout?
Do you have a large or small space inside?
Do you care about scenery?
Do you care about figures?
Do you have a large or small budget?
Do you like to build your own modelsâŚor just drop it on the track?
There are a few different O scales. The American definition is 1:48 scaleâŚand std gauge track scales to 5â gauge. If you go to Europe, it is 1:43 and scales correctly to 56.5" gauge (HO is derived from European O scaleâŚ87/2=43). There are two common types of std gauge O scale⌠3 rail and 2 rail. There are two basic levels of 3-railâŚless detailed (you may consider it toy trains) and super detailed (definitely models). Iâve never met a 3-railer whom wasnât convinced that he was sitting on a gold mineâŚand I canât recall meeting a non-3-railer who agreed with them. There are 4-4-0s available in O-scale.
O scale narrow gauge can be divided into a bunch of different groups, but Iâll focus on two: On30 and On3. On30 has become very popular in the past ten years thanks to Bachmann. It operates on HO track. In US history, 30" gauge practically didnât existâŚsomething like 40miles in the entire countryâŚbut, the track can be cheap (unless the ties bother youâŚand they seem to bother most On30ers that have layouts). On3 is very different from On30, 2-rail, and 3-rail. The track scales to an accurate 3â which was by far the most common narrow gauge. Until recent years, you had to be a craftsman to model in this scale. That has changed. You have to mail order everything, but it is excellent for the wild west thanks to MMI (Precision Scale Co)'s 4-4-0s and Accucrafts 2-8-0âŚboth of which are being offered in both On30 and On3. I know a few On30ers whom have switched to On3 as the rail spacing of On3
When I got back into rail roading I faced the same question. I have a ton of Lionel O gauge stuff, some going back to the 1930âs and 40âs with the latest being of the 1970âs vintage. I basicaly had a 4â by 12â 0 gage layout with an added section making it in to an L shape.
I decided to go with HO thinking I had room for a RR empire. After I got commited to HO I learned that O gage rolling stock turned a lot sharper than HO. For example 027 turns in 27 inches and O in 31 inches whereas HO needs a minimum o 36 inches.and for bigger locos and cars 44 inches is small.
But with that said Iâm still glad I went with HO because the size of the equipment as well as structures are much smaller and being small you can have a lot more and a good looking layout because the absence of detail in scenery is not missed as it would be on a O gage layout. In my opinion O gage has to be done really well or it looks toy like.
ummmm HO âscaleâ needs to be done really well or it looks toy like too, as does any scale you choose.
On30 is not HO track, yes the rails are the same distance apart and you can run On30 stock on HO track, but, On30 track has longer ties than HO track and they are spaced very differently, On30 track is only very slightly more expensive than HO from Micromark and the small difference is worth it in the appearance.
While yes I agree you can fit more HO âitemsâ into the same space as you can O, but how many bite off more than they have the time or money to chew, dream of a huge HO layout with lots of track/engines/structures only to build 5 different âplywood pacificsâ in 10 years, never get any of them anywhere near finished and then âpop-offâ leaving a ton of boxes that they never even opened or used full of kits and rolling stock for the family to dispose of?
Like I said in the begining, until you are sure of your goal you cant decide on the way to get there, everyone else has (and is entitled to) their own preference and opinion for their goals.
