Hi- Went to the local Lowes to scout out materials for my new layout. I couldn’t believe how badly warped all of the plywood was. The thicker/more expensive stuff (3/4") was better, but it’s quite expensive. My layout is odd shaped, but would require about four 4x8 sheets.
I am planning to use 1x4 framing under the table, but I’m not sure if it’s better to simply add more framing, use a thinner plywood (1/2 or 3/8?) and hope that I can coax the potato chip plywood flat, or would it be better to go w/ particle board or MDF?
I would imagine the thinner the table top, the more stiffeners I would need under it to prevent sagging. But more stiffeners means potential interference w/ under table accessories.
Suppose what I’m asking for are some opinions regarding table top materials, thicknessess and/or spacing of the cross braces under it. Is there a good balance?
BTW: Not interested in a foam top as I don’t think it’ll hold up w/ my son playing on it.
Thanks.
