Best batteries
what are your recomendations for the best batterie to use in a big hauler? I’m putting saddle tanks on so I have more room in there.
My battery preferences in order of value for money.
Gel Cell, but only if you can’t afford:
NiCd. Best value for money overall.
NiMh. Not bad but have only half the useful re-charge cycles compared to NiCd.
Li-Ion & Li-Pol. Not my cup of tea just yet. Too many issues with charging and self combusting.
Danke, I’ll go with the NiCd batteries. Self combustion isn’t what I’m looking for.
Personally, I’ve become quite fond of the AA NiMH batteries. They’re cheap, and available in almost every grocery store you walk into now. I’ve found them to be far superior to NiCad batteries in terms of run time per unit volume, as well as running characteristics. They put out a full voltage for the vast majority of their life, then die very quickly–almost instantly, as opposed to NiCads, which hold their voltage for a good while, but then taper off for the last 15% or so of their cycle. Also, NiMH batteries don’t have the problems with “memory” that NiCads have. While this isn’t as much a concern in the garden as it is with something like an electric shaver, it’s still a phenomenon inherent in the batteries and does effect battery life over time.
My preference is to use the 4AA battery clips to hold the batteries, and have these clips accessible for exchange. This accomplishes two things. First, it allows for continuous operation because you can simply swap out the batteries when they run flat. You don’t need to pull the locomotive to charge the batteries again. Second, it allows you to isolate the occasional bad cell, because you’re charging each cell individually as opposed to as a complete pack. Just (properly) dispose of the bad cell, and replace it with a new one. You can also buy larger NiMH batteries (C and D size) for incredible run times that you simply can’t get with NiCads.
One other advantage to the AA batteries is that you will always have ample supply around for things like digital cameras, portable CD players, and myriad other things that use them. Their only drawback is that they don’t do the best job of holding their charge in storage. I’ve tried using them in my daughter’s toys, and found that they don’t last nearly as long as alkaline batteries in those circumstances. But, with a 1-hour charger, you simply pop the batteries in the charger before you start heading outside to clear debris off the track and bring out the rolling stock. By the time the track’s ready, so
Just how many would I need to run a loco.? Is it better to by them as wraped packs?
I run all of my locos on 14.4 volts (12 batteries). On the older installations, I’ve got two 6-cell packs built into the tenders of the locos. These cannot be removed. On newer installations, I’ve got three 4-cell clips that can be removed by taking off the coal load of the tender. On this installation, the batteries can be removed from the clip and dropped into the charger for easy recharging and replacement. (See notes above about isolating bad cells.)
I like the removable packs because I can quickly swap out old for new batteries and keep running, as opposed to having to remove the loco from the tracks to recharge the internal battery packs. As the older installations fail, I’ll probably replace them with the 4-cell clips. Certainly my future projects are going to be done that way.
Later,
K
NiMh Are great as they don’t really have the memory effect problem like NiCad and these days are just about as cheap…depending where you buy them. I wasn’t aware of the combustion problem with LiIon. Most of my photo equipment is LiIon and haven’t had any troubles at all for over 5 years.
underworld[:D][:D][:D][:D][:D]
I’ve put this into a couple of other forums. If you want to get the latest on battery technologies try going to this link and choose the Batteries & Chargers forum. http://www.rcgroups.com/forums/index.php
Electric RC flying is growing by leaps and bounds and there’s a lot of practical experience and info in this forum.
My recommendations for battery types in model RR would be NiMh 1st then Nicad. Nicads are heavier and have less energy density. Both types are proven and are safe if used properly and not abused. They both can withstand heavy amp loading and physical abuse. Over discharging will not cause safety hazards and charging at high rates is also safe with most. Obvious cheapo batteries found at bargain basement prices probably will not provide good results.
Nicads are probably going to be harder to find in the future because of environmental issues. Modern Nimh’s made for high discharge applications are affordable and readily available. I’ve used them for 7 years of flying in my high amp applications (35+ A). They obviously do wear out but the amp draws in model RR’ing are nowhere near what we do in flying so their life span should be very acceptable.
Lithium technology has been a real boon to RC flying because of the energy density issue. A lot of voltage in a light weight package which is very important in RC flying. In model RR’ing weight is probably not an issue but size form factor might be. The problems with Lithium Polymer (LiPo) batteries is that they are 1- fragile (thin foil packaging), 2-can only be charged at their mah rating, 3-should not be over discharged, 4- shouldn’t be discharged at higher than they are rated (this is pack specific and noted on the packs), 5- more costly than Nicads and Nimh’s. Now if you take into account all these issues they p
I have no arguments with any of the above, except.
AA NiMh/NiCd batteries have an inbuilt max current capability. Anything over ½amp (500 ma) draw will be supplied by the cells but at the cost of a significant reduction in the life of the AA cells. They are designed to give a low current for a long time.
Plus, NiMh only have half of the lifespan of NiCd cells.
So, my opinion is NiCd still provides the “best value for money”.
But NiMh batteries have twice the capacity per charge as NiCd, so even with half the charge cycles, your total life is going to be roughly even. I’ll take longer runs per charge over long-term lifespan any day of the week–especially on weekends when I’m running trains. [;)] Since I use the NiMh AAs in other things around the house, I’m routinely picking up the occasional 4-pack from Wally World anyway. (Less than $10 per pack)
Later,
K
Hi Kevin. Once again I cannot find fault with the argument.
Except: I can only really discuss the various chemistries available here in Australia.
I acknowledge the logic of having twice the capacity equalising the useable life spans.
However here in Australia we cannot get the really high capacity NiMh cells in other than SubC for a reasonable price. I have never seen such things as 4/5ths A’s available over the counter. Or even high capacity D cells. They don’t exist at an affordable price anyway.
3,300 NiMh sub C cells, the biggest I can get readily, cost me more than twice the price of 2,400 mah NiCd Sub C cells. So, I guess, at least for Australia anyway, we are back with NiCd being twice the value of NiMh.[swg]
Oh and by the way, the life span of both NiCd and NiMh chemistry for AA size cells will be shortened by overcharging and overdraining.
There are no big online discounters of batteries in Australia and importing them is impractical as the freight costs would be a killer.
Here are a couple of vendors selling various Nimh and Nicad cells. I’ve dealt with the first three and have had good service from them. The cells listed are high output cells and will hold up to our hobby needs. I really am not familiar with the inexpensive bargain cells available at discount stores, so I can’t venture an opinion on them
http://www.cheapbatterypacks.com/main.asp?sid=696862&pgid=loosecells
http://www.battlepack.com/loosecells.asp
http://www.maxamps.com/index.html?lmd=38519.529109
http://www.batteriesamerica.com/newpage8.htm
Again I highly recommend going to the rcgroups link I posted and checking out the battery forum for additional info. I would suspect that there are RC car forums out on the world wild web that have info also, though from my understanding the RC car guys usually are using those larger sub C size cells that might not be applicable to model RR’ing because of their size.
BTW, Tony’s RC system looks to be the one that offers the best bang for the buck and I know he’s been in this arena for a long time.
Dave
You might try eBay or online sources such as the ones dottney has listed. I find great deals on large and small batteries at Hamfests but I have also bought some in off season from people on eBay.
Underworld.
With respect, you might try reading the last line of my posting again.
Man I opened a can of worms here. You guys started talking electronics and lost me. Thats why I like old things at most three wires, I can figure that out. Give me rods and gears anyday.
S&G,
I hope we didn’t muddy the waters for you. Essentially if you want to do battery power I think most of us agree that using Nicad or Nimh cells is the best way to go. Unless you’re an electronics tinkerer you’ll be best off using something like Tony’s RCS system. He offers a complete package or a speed controller that you can use with an inexpensive RC transmitter & receiver (Hitec’s Ranger is only $40-see http://www2.towerhobbies.com/cgi-bin/wti0001p?&I=LXARP0**&P=).
There are other RC systems out there but as I said before Tony’s system seems to be the most bang for the buck- his EVO Basic is $60. So for the radio system & speed control you’ve got $100. Then you’ll spend some money on batteries. Obviously if you want bells & whistles (literally) you spend more.
Connecting everything is really pretty simple- 2 wires from motor to speed control, plug in the speed control to the radio receiver, plug in the battery pack to the speed control.
Again hope this helps,
Dave
With the exception of three of my locomotives (2 steam - 1 clockwork) all of my locomotives use SLA (Sealed Lead Acid) cells. They are nice and heavy -thus improving my tractive ability (something you need with 12 and 16 wheeler locomotives). They have exact rectanguler shapes that are easy to fit in fireboxes and under side tanks. I have run across the current limiter effect of NiMH batteries -and this can be less than pleasing when trying to drive a large number of power axles… I did try paralleling up NiMH batteries to get the required current draw -but in the end simply dropped in a 6V 4.5Ah SLA that did the job with no fuss.
I have tried “Sodium Sulphur” batteries (ex UPS) but the charging requirements were dire, (the batteries were litteraly too hot to hold). So -although they did re-charge 6Ah in under 15 minutes it took nearly an hour before they were cool. They were lighter than the SLA and had a higher charge density. They may be fine for electric vehicles -but for model locos they are “one step beyond”!!!
At the momement I see no reason to change from SLA.
regards
ralph
I did see the last line. I thought there might be some Ebay dealers in Australia or New Zealand. Are there hamfests (amateur/short-wave radio shows or swap meets) near you? If there are it might be worth a look.
Thanks Guys, I think I’ll use whatever Goodson puts in for the mauler, but I’m using AA’s for my other loco (an 0-4-0 sled) The post is in scratch building under Drive Chain.
Two Way Radio Battery
TwoWayBattery.com is your source for high quality two way radio replacement batteries, chargers, eliminators and accessories. Enjoy our 30-day money back guarantee and same-day free shipping on all orders over $149.00.
