I have an old athearn GP50 shell that was razor sawed into two pieces(and quite cleanly I might add!). After test fitting it to a chassis, I’m sure that it could be put back together. The only problem is that one end of the shell is squeezed together and it makes it difficult to keep aligned when re-attaching the two halves. Any suggestions on keeping it straight while the glue dries?
RW,
After following gvdobler’s advice on glueing the shell, glue styrene reinforcements to the inside. Use a thickness that is strong enough but won’t interfere with the frame or motor.
About 1/16" max.
Bob K.
Thanks Bob. Was thinking about doing something like that, as well. Now to figure out how the shell will be attached to the frame. I must have been planning on making the locomotive into an SD50 or something because the tabs that snap into the frame are missing. Whew, this project seems like it’s getting a little out of hand.
