Thanks in advance.
I have the following, ('m still DC, HO)
- SPDT (on)-off-(on) toggle,for twin coil PECO turnout motors (PL-10)
- SPST momentary push button normally open, for “which turnout is this anyway, indicator light”
- BI-Color (red/Green) LED in “dwarf” housing L130WDT/EGW from this linked pdf http://www.smcelectronics.com/DOWNLOADS/LED03.PDF
- more yellow 5mm LEDs than I need.
- appropriate resistors for all LED applications
wiring the toggle to the PECO is not the problem and I will use a CDU
The puzzle I want to solve is:
I want to use the LED dwarf to indicate turnout position in a yard I’ve constructed. This yard, small though it is, has 10 turnouts and I hope to have my seven year old operating it. What I want to do is use the push button to light a yellow, non protypical, light at each turnout. BTW, The push buttion and the toggle are mounted side by side along the edge of the yard, in proximity to the trun out. the whole yard is 9’ and is along the near edge of the layout.
Question: using a spare track power transformer/power pack, (how) can I power the red/green portion of the dwarf on the DC side, and via the push button, the yellow “combined” aspect on the LED? Keeping in mind that the red or green will always be burning depending on the turnout setting. I’ve read here and elsewhere that AC will do that, but is there an alternative, and how is that hooked up, espically in light of (no pun intended) the red/green always on, situation?
The point is that the son and his old man would like to be able to press the push button before or after setting the turnout. That way he/we can tell which turnout in the maze we are dealing with. (This would also prevent the look from being too un-prototypical unless we’re
with a DPDT MOM/ON switch.
