Hey Big Boy!
Look at the Specs!
Allegheny’s rule, hands down
MY Rails or YOURS!!!
Hey Big Boy!
Look at the Specs!
I usually root for western roads, but the C&O is far more appealing than the UP, so the Alleghenys are swell.
The Duluth Missabe and Iron Range articulateds are overlooked too often. There is a nicely preserved on in the railroad museum in Duluth MN. The cab is as big as a living room! It looks like all it would take is fuel water and some grease and it would run.
Dave Nelson
The Union Pacific Mechanical department, and thier traffic department were very much in sync, so the Big Boys (and Challengers) were used as intended, and to thier fullest capacity.
I don’t think that the two groups ever talked in the C&O’s case. The Allegheny was an answer to a question no-one asked. It was never used as its design was intended. It should have been pulling trains at an average of 35 to 45 mph. Instead it was dragging coal at 15 to 20 mph. And the Virginian did no better with thiers.
The Big Boy had compromises to its design, the 4 wheel lead truck (and this applies to the Challengers as well) was costly (more axles, less weight on the drivers, made the front and rear engine rods and valve gear not interchangeable, etc. etc). Due to Wyoming coals lower heat content compared to Pocahontas coal, it needed a bigger fire box, and instead of using a six wheel trailing truck, the front of the fire box was over the two rear drivers. On the UP with was not as big a compromise, because to the larger clearances. IMO, the Big Boy should have been a 2-8-8-6.
One of the most efficient users of steam locomotives was the N&W, specilfically the improved Y5/6 classes of 2-8-8-2. These had starting tractive efforts SIGNIFCANTLY higher than the Big Boy, DM&IR’s Yellowstones, and 50% greater than the Allegheny. They developed maximum horsepower in the 15 to 25 mph range, and pulled coal hoppers at that speed. Yet, they were weight was less than 75% of the above locomotives…
Y6b 2-8-8-2 or the B and O EM-1 (2-8-8-4)
Yes the Big boy was nice but designed to haul heavy trains at speed on the long western grades. The Allegheny had the biggest firebox capable of creating steam to haul the brutal eastern grades. Yes the “Alley” can get up and go with passenger cars (and it did too) the nature of the territory meant that there was not much “room” to run.
It was either up hill, down hill or sideways. Give me the Y6b any day. Yes it creeps but only the “Jawn Henry” ever developed more starting effort. Nothing is as sad as the “engine that can’t”
I also recall a Triplex 2-8-8-8-0 was built but did not see much use because if memory serves there was 2 issues. The first was the steam generation, the boiler was too puny to feed all those hungry cylinders. And the second was that while starting heavy loads the rear set of drivers under the tender would break loose and slip, robbing the rest of the engine of good traction and steam.
And by the way I think the Gross weight of the Alley was greater than that of the BB.
Gosh! Maybe that’s not the best signature quote. Or whatever that thing is… Yeah, I know the Alley was heavier than the BB, but (i’m sure you’ve all heard this) the Big Boy and the Alley never really competed in the same area of work. The Alley was used in low speed coal drags (on the C&O, anyway), while the Big Boy was used in high speed freight. Thus the war between the locos continues.
(though I hate to admit it [;)], the Big Boys and the Alleys were surpassed by the N&W’s Y class locos)
Hmm. Let’s leave off the Y6’s for a minute. Take the BB and assign her to the C and O or N+W etc and the Alley out west. The result probably would be interesting.
The Big Boy would do okay everywhere it could fit, just like the Challengers did okay on the Clinchfield. The Allegheny would do okay on the mountains, but would slow the road down between Larmie and Evanston. Her firebox is sufficiently sized to work okay with Wyoming coal (the same can not be said of the N&W A which was designed specifically for high heat content Pocohantos coal).
This too maybe debatable , I will not claim in any way expert status but me thinks itme to hit the books.
I’ll be back"
BIG BOYS FOREVER!!! I, being a Union Pacific fan naturally support the Big Boys. But instead of basing my arguement solely on that, I have a great deal of evidence to support my conclusion that the Big Boys were better:
Firstly, in the arena of size, I do not dispute the fact that the Big Boy engine itself weighed less than the Allegheny. However, the Big Boy with tender weighed appreciably more than the Allegheny. Furthermore, and even more importantly, the Big Boys had the greater adhesive weight (weight of the locomotive supported on the driving wheels), in part because the firebox was suppoted over the last two driving axles in addition to the four wheel trailing truck. Why this greater adhesive weight is relevant is that the adhesive weight affects the factor of adhesion, giving the 4000 class more “grip” on the rails. And don’t think that locomotives as large as the 4000 class and Allegheny didn’t have wheel slippage: they did, and I can prove it. Furthermore, the Big Boys were larger in other ways: they were longer, and more.
Secondly, in the area of pulling power, I of course acknowledge the Allegheny’s greater horse-power. But let us not forget that the Big Boys had a much greater tractive effort. And while there were some locomotives with greater tractive effort, no locomotive had greater tractive effort and horse-power.
However, railroads have locomotives to pull trains, not to brag about having the largest locomotive. As such, we should pay even more attention to the Big Boy’s and Allegheny’s perforance and service than their basic specifications. The 4000 class locomotives were very reliable, and were very efficient and relatively inexpensive to operate and maintain for locomotives of their immensity. Of course, those who wi***o detract from the Big Boy’s legacy point out that they burned up to 12 tons of coal per hour and used thousands of gallons of water in the course of a run. But what they conveniently omit is what a cost saving
I have to go with the Big Boy. I have the Pentrex DVD featuring film of all 25 Big Boys in action, and they are so cool! Part of the reason I took this name is that, for a number of years, when I lived in Denver, I saw this engine all the time. You can see it too, at the Forney Museum.
I’ve got to get that DVD! BIG BOYS FOREVER!!!
I am going to say that there are many good points for both engines. However I post a link here to help look at it from the Alley’s point of view. It will save having a mass of large sheets on this forum.
http://www.steamlocomotive.com/allegheny/
Keep in mind that the vicious grades never gave the Alley room to run. In fact she is capable of more horse power at the drawbar than the Big Boy at 40 Mph. I could understand this to mean from a power point of view all things equal, the big boy will not be able to keep up with the Alley. In a 200 mile run on the same track same loads etc I think the Alley would be first in.
It is unfortunate that such a demonstration was never done.
I though the N&W Y6 2-8-8-2s were more efficient than the Big Boy and Allegheny in every way. But of those two, I’d give the award to the H-8.
AggroJones,
The 2-8-8-2’s were indeed fine engines but the C and O found them to be Shop Hogs and not up to the task. They were about 20 years old by the time the 2-6-6-6’s were ordered.
But as stated before, the 2-8-8-2 Y6’s may be the finest drag engine there was.
I run the Microsoft Train Stimulator. I wonder if there is a way to download a Big boy and a Alley as well as a good route for them to run on. Perhaps I could try to time a run between the two.
Today my question is: will we ever have the chance to see one day a Big Boy return to rails after having been restaured?
ddechamp71,
If you follow the embedded links to the “Bigboy” on the Alley’s Web page which I posted link to earlier you will eventually find your way to most if not all the Bigboys in the USA and prospects for restoration.
Good Luck and hope you find what you are looking for.
Lee
Sorry guys but Ive seen movies of both these behemoths, and between an Allegheny slugging a coal trian along at 15 mph -vs- a Big Boy hauling a mile long frieght at 70 mph…
…the BIG BOY wins HANDS DOWN!!!
That was a mighty, mighty impressive scene once upon a time to see a loco THAT BIG giving express trains a run for thier money! now imagine that train double headed with 2 BB’s moving the bacon at 60 mph.
