I have the Blue Line Big Boys which allow you to shut off the smoke feature with a switch. They use a liquid as you suggested and it only lasts a short time before you need to refill it. On a large club layout, it would run out of liquid and the smoke units should not be turned on without liquid in them. Like any smoke producing liquid, it will start to get things oily around the layout if you use the smoke all of the time so it is better not to use it very much.
All of the smoke units that I own have either a switch or a function to activate or turn off the smoke, but I do not have the new Paragon Hudson.
CZ
The information below is from the MR testing on the Paragon Hudson that you asked about.
Function #7 activates the smoke unit.
Sound and smoke. Both sound and smoke effects are available to DC and DCC users of the J-1e. On DC layouts sounds are limited to background effects (such as the air pumps and steam releases) when the model is at rest, and chuffing sounds synchronized to the motion of the drivers when the model is under way. I also triggered the sound of squealing brakes when I decreased the throttle abruptly, and could ring the bell and blow the whistle, using our power pack’s direction switch.
Broadway Limited also sells the DC Master analog DC controller ($39.99) to be wired between the power pack and the track to offer easier user control of the bell and whistle. You can also use the AUX button on the controller to turn the smoke unit on or off. A sl
Pour fluid down the stack and it will start the smoke. Read the instructions and it should show how to turn it off. Lets buy an engine with chuffing smoke as a wonderful new option and not use it.
