Noticed the brass hybrid J3a hudsons and ATSF 2-8-2s will have Paragon 4 decoders…hopefully they have better QC for those. I personally wasent a fan of the p3 sound, so I hope they change it up once again.
Maybe BLI finally conceded that the P3 decoders were a bust and a re-design was paramount to them moving forward. Yes, hopefully the P4 will turn out to be more reliable than their older sibling.
There’s times I wished Broadway would “fess up” and let the customers know what problems they’re dealing with ala Jason Shron at Rapido.
I’ve had awful luck with my P3 locomotives and — in BLI’s defense — they have made a great effort at making things right through the service department and I give them credit with that.
The latest revision (H) which has the “Go-pack” plug on the board is probably as far as they can go with that architecture.
I sure hope they redesigned the board from the ground-up. I imagine many of the sound files will be the same unless they spent some time making new recordings, which they sometimes do. My nephew accompanied one of their people here in Cleveland while making some recordings of Alco 244s.
I have several BLI locomotives, steam and diesel, that are Paragon models, factory equipped with QSI Quantum sound decoders. They can be a bit wonky, especially on the diesels with lighting and consisting. But, overall, performance is acceptable.
I have two Paragon 2 locomotives with a factory installed proprietary decoder from BLI. Both of these locomotives are steam, and the sound and overall performance are fine.
I have avoided the Paragon 3 locomotives because of all the complaints that I have read about performance faults.
So, when I read about Paragon 4, I just figure that it is best to sit back and let others take their chances before I dare buy one.
I can’t seem to find the discusion about BLI moters being 3 pole and causing problems with Paragon 3 decoders? I contacted BLI about P4 motors and got this back quite quickly;
Info
11:05 AM (2 hours ago)
to me
Hello Jack,
“Paragon 4 engines have a 5-pole varistor motor in them.”
What the heck is varistor you ask?
5 pole motors are better than 3 pole. 3 pole motors CAN be good, but the specific ones they used in their par3 models drew too much current, causing the decoder to malfuction.
BLI used to use 5 pole motors before paragon3, for some reason they chose to cheapen out during paragon 3 from the very first loco (PRR L1s) to the very last. Even though from the beginning people were already having issues.&
