I am thinking about blinding some drivers on this engine. Would the center driver or the rear driver be better for going through #4 atlas turnouts. This is a brass engine it it matters.
On the prototype, and on most scale counterparts, it is the practice to place blind drivers in between outer ones with flanges. In the case of the BLI 2-10-4’s, for example, the center driver set is blind. I think it is best for the front truck to have a flanged driver nearest it in your case.
Crandell
I would blind the center driver to prevent problems in tracking. If the drivers can move from side to side a little, you shouldn’t have a problem with #4 turnouts then.
Looking at plan and photos in Model Railroader Cyclopedia - Volume 1 STEAM LOCOMOTIVES the Russian decapod either came with all drivers flanged or had blind #2 and main drivers. The latter left two flanged axles at each end of the locomotive.
This is in line with other locomotives I am familiar with which had blind drivers - everything from the Brunel-gauge 4-2-4T with the highest drivers ever to the JNR E10 class 2-10-4T and a 2-8-2 that Crandell (Selector) posted some years ago.
Bear in mind that blind drivers usually don’t have tapered treads - they’re cylinders, not cones.
Chuck (Modeling Central Japan in September, 1964 - with a blind-drivered 2-6-6-2)
Have you tested the engine going through Atlas #4’s?
How much sideplay is there in the drivers? IIRC, the PFM Russian Dec could go through some fairly sharp curves. Don’t know about the Sunset engines.
Andre
Blind drivers are wider than flanged drivers too. You can get blind drivers from Bowser and Greenway products depending on what diameter. The axle sizes will be different. I have a Sunset I1sa 2-10-0 that had blind drivers on axles 2,3,and4. They tended to drop between the rails and was a pain in the neck. I had replaced all the blind drivers but the center axle. It now negotiates curves and turnouts as low as a #5. I do not have anything smaller to try on. I can’t see why your Russian can not go through a #4. They were a lot smaller and shorter wheelbase than the I1sa.
Pete
