If you want to have workign signals or automation, then you need block detection - use the BDL168 for that. If you plan to be the only operator and only have 3-4 locos running, you don’t need an 8 amp set, the 5 amp system will be MORE than powerful enough. Plus 5 amp power supplies are a lot easier to find.
The Magna-Force power supply from Tony’s is NOT an 8 amp capable power suppyl regardless of how they try to sell it. Their own test results show a serious drop off in output voltage when getting close to 8 amps. It’ perfectly fine for 5-6 amps.
Block detection is one example of the use of sensor technologies for model railroads. There are a number of other ways you could do this in addition to detecting current draw. I am in the process of writing up a comprehensive series of articles covering the various kinds of sensors. The first article is here (http://coralfringe.blogspot.com/2010/01/sensors-for-model-railroads-1.html).
