I would hazard a guess that they are NOT DCC equipped. ‘DCC ready’ means that they have a socket and are ‘ready’ for a dcc decoder. ‘DCC Equipped’ means that they already have a decoder in them.
The link you provided also says ‘DC Sound’ which tells me those are conventional DC locos.
Short answer: No RTR locos come with DCC or sound. Readers Digest version: Most RTR locos only have plugs for DCC that match the NMRA standard. Some of the cheaper new stuff does not come with any plugs. Most of the stuff that is over 10 years old and the afore mentioned cheaper new stuff has to be modified in order to install DCC. All of the above has to have a separate sound board of your choice (QSI, MRC, Soundtraxx etc.) installed piggybacked on the DCC board. You also need to add speaker mounts and speakers.
To clarify the previous answer, Atlas makes a series of HO Scale locomotives that have QSI sound and DCC installed. They are called “Atlas Master Gold Series”. Walthers, who now owns LifeLike, sells the Proto 2000 units with QSI Sound and DCC installed. These two manufacturers, in my opinion, make some of the nicest plastic models with sound.
They are basically RTR, since you can take them straight from the box to the track and call them up with your DCC system and start running them. Of course, there are detail parts to be installed (like pilot handrails).
Thanks for that. I got to thinking after I made my post that different manufacturers define RTR in different ways. There is no single definition for RTR.
Athearn’s RTR lovomotives for the most part are DCC ready with NMRA approved socket. You are on your own to pick out and install the chip of your choice. I believe Athearn still has some non-DCC ready stuff at the low end of their RTR line. Athearn’s Genesis locomotives are all DCC ready (NMRA socket installed). Sound and DCC is offered as an option on the Genissis line or you can purchase the DCC chip, sound board, speaker mount and speaker(s) of your choice.
Not necessarily, I bought a Proto1000 SW9 that stated on the box the it was DCC ready but you had to solder a decoder in to make it DCC. Under PROTO’s rules all locos are DCC ready [:P]
Previous answers you have been getting are not even close to the truth in some instances.
Blue Line locomotives have sound and a DCC socket so you can use your own motor control decoder. They will run on DC and you will get sound, but it will not be as controllable as it is if you put a motor control decoder into it and run it on DCC.
Bachmann, Proto 2000, Atlas, and Broadway Limited Paragon locomotive all have DCC and sound already installed if you purchase the correct version. Bachmann, for example, sells without DCC or sound, with DCC only, and with DCC and sound. Proto 2000 come with the same three options. Broadway Limited, too, came with or without sound.
You have to read the descriptions of what you are interested in to make sure you get one that has DCC and sound. If in doubt, go to the manufacturer’s web site and read their descriptions.
I haven’t looked at your linked engines when I write this post, but if any of them happen to have an MRC sound decoder, you should understand that a great number of posters here over the past eight months or so have reported serious and frustrating problems with them. They sound pretty good, and they run the trains well…the problem is in programming the various CV’s, and also some of them just seem to develop problems related to quality control very shortly after you begin to use them
Man im confused, so lets say i went with a Atlas Gold series, does that have a MRC decoder? Should i stay away from a MRC DCC system? Or should i not use DCC at all and just use DC?
Yeah, but fortunately the store owner was pretty cool and popped the shell off to verify it DCC rediness. He gave me a deal on the decoder AND instalation so I bought it anyway. Sorry for not adding to the original posted question, but I thought I’d share my experience.
As I stated earlier, the following brands have QSI Sound factory installed:
Proto 2000 w/Sound
Broadway Limited Paragon Series (NOT BlueLine)
Athearn Genesis with sound use factory installed MRC decoders. MRC decoders are also available as an aftermarket purchased and can be installed in any locomotive. I would avoid the Kato unit as the owner has equipped it with an MRC decoder. As Selector said, many users are not satisfied with the MRC decoders. The complaints against them range from difficulty in programming, losing their programming, etc.
It’s not as daunting as you fear…DCC is a lot of fun!
Darn i liked that Kato unit too, if i could just find a BNSF unit that was DCC installed with QSI sound and alternating ditch lights i would be happy. I just cant find one~
I really want this one I know it has a MRC decoder in it, but do you think it would be ok? If not could i replace it later? I will be using a MRC Prodigy DCC system too. (unless you think i should avoid MRC all together?)
