Hi all,
I’ve been looking at building a bookshelf/bookcase layout for my apartment. I can go up to 2’ deep and, ideally, stay around 6’ long, with temporary space for up to 4’ of plug in staging on one end, and a 1’ tail track for a run-around on the other, temporary for operations.
I want to stay in HO so that the rolling stock and structures I make I can carry forward with me, but luckily my prototype will be doing 36’ or shorter rolling stock, a bobber caboose, and a small 2-8-0 or 2-6-0 for motive power. Using steam is definitely tricky for such a small layout, but I anticipate I can make it work.
Right now, I am starting from the MR Thinbranch extension to the Virginian, from 2013, as it has a runaround, mine siding, and operational interesting with the switchback, but if anyone else has some favorite smaller layouts of that size give me a shout for inspiration - this is still very early stages of planning.
Anyways, here’s the Givens and 'druthers:
Givens:
HO scale
Copper Range Railroad 1920s or 1930s
Copper Mine Serviced
22’ Wood Ore Cars, 34’ or 36’ Wood Box Cars, Short Steel Coal Hoppers
Operations potential
18" Minimum Radius
#5 minimum turnout
DCC
Built on bookcase
No more than 2.5’x7’, maybe L-shape but L-leg no more than 1.5’ deep 3’ long
Plug-in fiddle staging, 1 track, no longer than 4’, plug-in lead track on other side if layout is 6’ no longer than 1’ long, up to 1’ if L-shaped
All electronics, plug-in components, etc. fit in space behind bookcase
'Druthers:
22" Minimum Radius
#6 minimal turnout
2’x6’ plan
Coal unloading for mine boiler house
siding at shafthouse for loading lump copper onto flat cars
mine supply dryhouse for unloading boxcars and flat cars
Hand-laid track, probably manufactured turnouts
Sequence or event deck opera
