I have a pet peeve. Its broken or missing stirrups on rolling stock. When looking through Ebay listings, the first thing I look for is if all the steps are intact. If the pictures don’t show them all, I ask. I’m not sure most people realize how easily the steps are broken and they don’t handle rolling stock correctly to prevent breakage. Oh well, a pet peeve is a small thing that bothers you way more than it should Any other pet peeves out there? Let’s hear um!
I hate it when someone begins a sentence with “Well, to be honest with you,…” Does this imply they are lying the rest of the time?
Better to have a solution for the problem than let it bother you so much. [:P]
I deliberately cut the sill steps off most of my rolling stock, and replace them with metal ones from A-Line. They offer three different styles, and you can easily make your own for styles not offered, using Detail Associates .010"x.030" flat brass bar.
To install them, use a #75 or #76 drill bit in a pin vise to drill suitably-located holes in the bottom edge of the car’s sides, securing the steps with a couple of miniscule dabs of ca.
If the car’s sill is too narrow, use solvent cement to add short lengths of Evergreen .030"x.080" strip to the inner face of the sills, as shown below. Allow the bond to fully cure before drilling the holes. You’ll also need to trim away a small portion of the car’s floor to accommodate the strips.
Here’s the finished car:
…and a different style step on the “B” end (right):
Being a cheapskate if I have to replace stirrup steps I make most of mine out of 26/6 standard staples and install them similarly to doctorwayne.
The photo shows a kit bashed car and its donor car.
Cheers, the Bear.[:)]
Very nice info Wayne and Bear!! I have some of the A line parts, just would rather not need to use them. There’s also the problem of match paint on the new steps.
Bear,
LOL, Not being a cheapskate…but a teenager in the 50’s, I’ve used Your way many times. Once painted, 9 times out of 10, no one will know and they don’t break off either.
Take Care! [:D]
Frank
That and “NIB Athearn SW1500”…Missing handrails.
To my feebie mind NIB means its a new engine and ought to have all the handrails and details.
There is so much stuff for sale on Ebay and so many less than honest people selling the stuff, that the above should be taken as a hint that the seller is not being up-front about the item’s condition. Your and my Feeble Minds need all the help we can get and there is a little help for us!
I used to just glue them back w/ a small piece of bronze or brass wire as a drilled dowel or reinforcement. Not a very good solution, have used staples and now will do as drwayne, fix it right.
And there there are these famous words.
“These was my Dad’s and I don’t know anything about them”.
Really? Hello red flag. I avoid such sales.
No fair showing a real car as the model.
(As if someone could produce that fine of a model…)
snark/on
Way back Walthers used to offer a bag of replacement stirrup steps which were nothing more than metal staples of various sizes. You’d split one off the block of staples with your fingernail or a fine knife blade. At the time we thought they were pretty wonderful, even if they look crude (if still finer than the plastic stirrup on some older models). Nobody dreamed back then of commercial aftermarket stirrup steps, grab irons, running boards, and ladders such as as we enjoy today.
Dave Nelson
[/quote]
Actually, I’ve gotten some whoppin’ good deals simply becuse they “didn’t know anything about them”…and I DID! Ya gotta know what you’re looking at though.
My eBay pet peeve: “Reserve not met” Either start at your reserve, or don’t have one. I don’t waste my time on those.
I use the A-Line metal steps and then paint them with some acrylic craft paints from Walmart or Hobby Lobby. There is a large color selection and I can always find something close and then tint a little with whatever color is lacking; you’d be surprised how close you can get it. Also, with such a small area to paint/match it is generally close enough especially after I weather the steps and lower body.
-Bob
I put a small piece of styrene behind where there is space below the car floor, to reinforce the plastic lip area before drilling at each corner. After the cement has set (I use Model Master styrene glue), I hand paint the added piece. Then, when I drill small holes to mount the DIY steps, there is just that bit of extra material there to prevent drilling thru the car side. I use either .020 or .025 steel or phosphor bronze wire, appropriately bent, then CA-ed in place, then painted. Using the 3 foot rule (or even the 1 foot rule! [:)]), the result is not too bad.
Cedarwoodron
Similar issue with passenger car modelers. Although a big step above the old 1980s-90s Rivarossi units, the Walthers varnish are more fragile, in comparison, and should be handled with gentle hands. I have quite a few stirrups that are either cracked, bent, or are barely hanging on at an angle. What adds to the dilemma with passenger car stirrups is that on a number of cars the stirrups hang ahead of the car end, making them even more vulnerable to accidental breakage.
If no one produces metal stirrups for Budds, I’ll have to look into forming replacements out of brass wire.
A compliment to Rapido in that the stirrups on their streamlined passenger cars are stronger and not so easily broken inspite of being the correct size as on this unit here:
Actually, since stirrup steps (and grabirons) are considered to be “safety appliances”, they are required to be in good repair. That means that if a car is received by a railroad, and has a safety appliance damaged, it must be repaired by that road before being sent on. The railroad does the necessary work (including painting the repaired area with whatever paint they might use for such work on their own rolling stock), and then bills the owning road for the labour and materials. That’s part of the agreements covering interchange, and all common carrier roads are participants. So when you can’t exactly match the car’s original colour, it still would be quite prototypical. Besides that, a little weathering will help it to blend in with the original - the lower extremities of a car are most prone to weathering anyway.
As for sill steps on passenger cars, it’s easy to make your own using Detail Associates .010"x.030" flat brass bar:
There’s info on that procedure (and a number of other things - you’ll need to scroll down a bit to get to the passenger car steps) here:
http://bigbluetrains.com/forum/viewtopic.php?f=22&t=2545
Another thing to remember is that rolling stock did get damaged and repaired on a continuing basis, so it wouldn’t be all that unusual to have a boxcar or hopper with a side panel or two repaired or replaced, and then painted with a non-matching colour. It gives your cars a bit of implied history, and should be considered an integral part of the weathering process.
[IMG]http://i23.photobucket.com/albums/b399/doctorwayne/freight%20cars/Lat
