Building a H0 SD40-2
Hi all,
I know this option is probably more expensive than picking up a 2nd hand SD40-2 from Ebay, but I’d really like to give scratch building a go, and make an SD40-2 and have the satisfaction of at least one loco on my layout being “mine”.
Does anyone have any thoughts on some good articles I could read up on, and companies I could source components from? I’ve already seen RRP and it seems either an Athearn or Atlas trucks are good to get it going.
Thanks
Mike
Cannon & Company http://cannonandco.net/ has just about any part you could want. They have some pages linked showing building things like cabs and hoods http://cannonandco.net/Links.html , and there are in-process photos of models in the “models” pages 1 and 2 on Cannon’s site of Elizabeth Allen’s SDP45 which could give you some ideas.
check out the Diesel Detailer .com website.
They have folks there that are experts, & many pages of info that you may find useful.
There are articles in threads for variying degrees of efforts.
I believe you can read much of it without being a member.
The other thing is to Research, Research, Research, the actual model you want to build.
The SD40-2 has so may unique features depending on the road it was built for, where it was built, to after it was built modifications…
Options are endless.
Best of Luck!!
Gidday Mike, regarding articles,
Model Railroader,
July 1976, Modeling EMD’s most popular six axle locomotive, (Build an SD40-2) by John Dhols. April 1979, Modeling an EMD SD40T-2, by Dale Olafson. October, 1984, Modeling a Southern Ry. SD40-2, by Jim Six. August 1986, *Union Pacific SD40-2, (*a Paint Shop article) by Mark Danneman. August 1989, Six axle SOO Line power. ( a Paint Shop article) by Charles Derus. April 1994, MKT’s SD40-2, by Carter Osborne. June 1994, Hiawatha-scheme SD40-2, (a Paint Shop article) by Keith Fink. January 2005, Build an upgraded SD40-4, by Eric Bergstrom. April 2006, How to detail and paint a Kato SD40-2, by Pelle Soeborg.
Wow, this takes me back to the 1970’s when people were kitbashing SD40-2’s because there weren’t commercial models available.
I did a pair of of PC engines way back then myself.
Thanks for all the advice,
I’m busy collecting parts together, and I’m just about to source a walkway/frame.
I quite like the Railflyer walkway/frames on Walthers, but I’m a little confused by the terminology used, and wondered if anyone could shed light on it.
All the walkway/frames have a reference like C5:E5, which stands for Conductor or Engineer side notch terminates between the 5th and 6th stanchion from the rear of the plate.
DFCO = (Distinguishing Feature) DFCO stands for Dropped Fuel Cut Off is also used on the various walkway/frame options.
I know there are lots of revisions for the SD40-2, so maybe it will help that I’m looking at modelling a late version bought by BN.
Thanks,
Mike
I have to say, never having done it myself, that this is among the most impressive accomplishments in model railroading - - - building and detailing locomotives to match the prototype.
Kudos to those of you who do it.
Athearn uses McHenery couplers, and they sell them under parts.
