Building an HO scale Keystone Shay (FINISHED, with VIDEO!!)
This Christmas, I was given a brand new Class A 20-ton 2-truck Shay kit by Keystone![:D] This topic will cover my progress as I finish it.[:D]
Here’s all the parts from the kit I’ll be using. Full dummy trucks are included in the kit.
The first thing I built was the engine. Some people leave the piston rods off, which probably makes it more sturdy (or maybe they’re just lazy!). After minor adjustments here and there, it works very smoothly.
The next thing was the cab. It comes in five major pieces, which have to be lined up just right and glued together. The front wall isn’t quite wide enough to meet the right side, so the gap will have to be filled and smoothed.
This is just to show you how small the boiler really is. The Bachmann Shay (or even an 0-4-0) is massive in comparison!
Loosely assembled. You can see some of the unused truck parts in the bin.
Here’s how I’ll be mounting the reverse light with a mini-bulb. The wires are completely hidden at most views, which will help it look better. I’ll be doing the same for the headlight.
Shining bright.[:D]
I’ve also started assembling some basic details to the boiler and tender. Beyond this, I won’t be doing much more until I get my powering kit from NWSL (currently back in stock![:D]). According to the listing on their website, it will include a 10x25mm can motor. I was going to try and fit a coreless motor I happened to have in the Shay, but it’s too big to look good. I think the NWSL motor is a Sagami or something similar, so it should still work very well.
More later![:D]
Great! I look forward to seeing the rest of the story. I’d love to see how to get a motor and gears into that tiny locomotive …
Thanks,
Marty
Darth
This is going to be great, thanks for posting. Are you going to use the Keystone trucks/wheels?
Oakhurst Railroad Engineer, I’d also like to see how it will all fit together.[:D] There are no good pictures that I can find of NWSL’s power kit, so I’ll make sure to post a picture of it before assembly.
Geared Steam, I won’t be using Keystone’s trucks or wheels. They’re the same soft metal that the rest of the kit’s made from, so they would wear out quickly, and the uninsulated wheels would short out.
Thats what I thought, does the NWSL kit drive throught the rear truck?
The NWSL kit is more like the MDC drive, but to a much higher level of quality. It includes full trucks, geared nickel-silver wheels, stronger sideframes, full side gearing, a middle transfer gearbox with about a 3:1 ratio, universals, and a can motor. The Bachmann trucks wouldn’t fit because they’re much larger than the Keystone Shay’s trucks.
Not to mention, the Bachmann Shay trucks are of poor quality … NWSL has replacement gears to improve them that I haven’t tried yet, but hope to in the future.
Marty
Got me thinking… Check that auction site, item # 230417673987
Allegedly brand new. Might be helpful.
This e-bay item is a Roundhouse 2-truck Shay and is quite a bit larger than the Keystone Shay. Anyone have one of the Roundhouse 2-truck ready-to-run Shays? How is the quality, noise, electrical pcik-up, etc.? and how would you compare to a motorized Keystone Shay?
I built one from a kit and it is OK, but not great .
Marty
Yes, I recently purchased a 2 truck RTR Roundhouse. It’s as bad as the kits are. Noisy as heck, bad electrical pickup, the covers underneath both trucks pop off when going in reverse, Unusable as purchased, but I expected this, so I have no complaints. An order to NWSL remedied all of these problems. I need to improve the electrical pickup, and the lights are LED (blue). It was DCC ready, after all of this, I almost have it to a usable model. I’ll be happy to put the NWSL gears on my Bachmanns anytime, the Bachmanns are superior in noise, pickup, low speed running. Why did I get an MDC? I wanted a 2 truck shay, and I wanted to do the MDC/NWSL upgrades just to do it, it was enjoyable. The picture below shows me breaking in the bullgear assembly.
Edit: As Fwright mentions below, I removed all of the line shaft gears except one, one is all you need to drive the line shaft, crank and the motor. As you are aware, on the MDC, these components are for animation only, and are not used to propel the MDC shay.
Marty
From all I’ve learned, the RTR Roundhouse Shays were assembled in China, but all the original design problems were present in the parts that were given to the Chinese assemblers. And they have had even more problems with inferior gears than the US-produced kits did. Net result is that unless lineshaft parts were deliberately left off or assembled disengaged during assembly, the RTR models will have split gears - it’s just a matter of how little running time you get before the gears split. The binding that results from all lineshafts engaging their drive wheels will happen in the RTR model, causing the axle gear to bind/split/crack. That’s if didn’t already split from the shrinkage issue with the axle gear material (similar to early Proto 2000 and early Athearn steam models produced in China).
For those reasons, I stuck with the kit versions of the Roundhouse Shays so that I could correct the deficiencies before and during assembly. The NWSL full regear kit (2 part numbers) is highly recommended as a step to a smooth-running Shay.
The Keystone/NWSL kit is another level of difficulty compared to the Roundhouse Shay - which NWSL warns you about. The Keystone Shay kit builds a model for static display. The NWSL motorizing kit substitutes key components so that the model can be a locomotive. However, depending on the run of the NWSL motorizing kit, the NWSL frame pieces may not be hard enough for long life. NWSL gets (got) these parts on special order from Keystone - for a while NWSL couldn’t get them sufficientl
The Bachmann trucks are really pretty nice. It’s just those plastic line gears, which split on many, and stayed perfect on others. I got the NWSL gears to replace the split gears on my Bachmann Shay. They’re made from steel and work absolutely great, but installation was a little difficult (especially on the rear truck). I had to put a dot of super glue on the flat side of each one to keep them from slipping out of place.
Here’s a few comparison shots for everyone.[:D]
Spectrum Shay > Keystone Shay
Frankenshay.
The Spectrum engine is more detailed, but that tiny engine is still pretty good.
I got my powering kit in the mail today. Unfortunately, one of the worm shaft assemblies is missing, and they didn’t give me the can motor I paid for (they specifically said it had the can motor, and charged me more for it, but I got the cheap open-frame motor instead). The parts I do have of the kit are very high quality, and after some quick simple tests, I’ve found they work very smoothly. It should be an excellent runner when it’s done.[:D] But, I’ll have to wait a little longer now before I can finish it.[:(]
Not fun when you don’t get what you paid for. In that position with a locomotive purchased online. Fortunately, it’s a Mantua and under warranty.
Thanks for your input to this thread all. I have one MDC two truck kit Shay that was put together by someone else. It wasn’t running and was basically just losely assembled. It’s running pretty good now, but still needs some tweaking. I trimmed off the teeth of the line gears which helped the engine to run much smoother. Still a bit of a jump periodically, so some more adjustment is still needed. Overall, I’m happy with the locomotive. It handles the steep grades well and I kinda like the clackety noise. Still have to work out how I want to do my lights, but that shouldn’t be to hard.
I also have another two truck and a three truck kit to put together, so insights into the assembly of all the different Shay kits helps. The solutions and tricks make life a lot easier. [:)]
Darth,
Great job so far! I hope the repowering goes well. I assembled one of these many years ago for a friend and the weak frame was a big issue then. I hope that you have less trouble than I did.
Marty and Fred;
A NG modeler from Mississippi has bought all the unused kits and parts for the MDC shay from Horizon. He is now offering what he calls semi-kits for sale. These are not standard MDC kits. The models are offered for specific prototypes, mostly HOn3. They do come with custom made brass parts to match the prototype, plus a complete list of extra detail parts you need for each prototype.
The chassis comes assembled with a can motor and both NWSL shay regear kits installed. Eight wheel pick-up is also installed. These are sweet runners. Depending on prototype, custom made cab pieces and brass frame end castings are included. He also has a line of custom parts, (brass), for shays, passenger & freight cars, and I think even other NG locos.
The instructions are a lot more complete than the MDC instructions and he even tells you which suggestions to follow from Jeff Johnston’s “The MDC Shay Handbook”.
I am currently assembling a Mann’s Creek #2, and a “generic” standard gauge shay.
I am not suggesting to anyone to buy this kit, nor am I “shilling” for the man. But he has taken what can be a good kit and made it great. I believe he advertises in the NG&SLG and possibly our host’s magazine. If you want more info, contact me via e-mail/PM and I will give you his contact info.
For those of you interested in MDC’s Shay kits (which I may also try eventually), this is the ultimate website on tips and tricks for building them.[:D] I found it to be very interesting, and the builder did an absolutely beautiful job on his Shay.[:D]
Awesome link. Thanks. [:)]
I appreciate the information. I had seen the notices about the improved and partially assembled Shay kits on a few Yahoo groups that I subscribe to. I have my own Roundhouse Shay to build - a Christmas gift was the boiler and detail backdate kit from Wiseman. My next order is the NWSL regear kits. Since I already have the Roundhouse kit and some of the details, the package price was a little daunting.
In my case, the Roundhouse Shay will be used on standard gauge, where the frame width is more appropriate for my 1900-era Shays. I had considered using Roundhous
I’ve now made a little more progress on the Shay. Since the only part truly missing is one of the worm assemblies, I can still do most of the major work.
This is the 99% complete kit. The transfer gearbox comes unassembled, but I had already done a little work before taking this picture. The motor shown was supposed to be a 10x25mm can motor, and not the cheap square motor. The square motor still runs well, but it’s not all that quiet. All of the plastic parts are made from Delrin, so they should last for a very long time. The pewter sideframes aren’t included anymore, since Keystone hasn’t shipped any to NWSL since 2004.
The truck kingpin mounts. They’re threaded, so you can either tap a hole to screw them into (like I did), or you can make the hole slightly larger and epoxy them in place. They go on the underside of the frame, and are a little fragile.
Before doing anything else, I mounted the kingpins to the trucks and set it down on its wheels. The kingpins pop into their mounts, so they can be removed easily for maintenance. Just remember never to pick the Shay up upside-down by the trucks, or it will probably pop off and fall!
Looking good so far![:D] Nothing’s actually assembled. I just wanted to see it on its own wheels.[:D] The hole for the kingpin mount will be covered by piping details and a tool box, so it shouldn’t look so ugly when it’s done.
Test fit and run of the gearbox (motor was actually running when I took the picture). I won’t be using that motor, but it sits at the right height for testing. The gearbox has an 8-tooth brass gear, a 25-tooth Delrin idler, and a 25-tooth brass drive gear, giving it a ratio of 3.125:1. It works quietly and smoothly, but bec
