Two potentially stupid questions regarding bulkhead flatcars.
1- the length (say, 50’) refers to the car’s length, not the space between the bulkheads, right?
2- Where can I scrounge up some prototype plans or drawings for a 50 footer? It looks like I’m going to have to kitbash some and I want to make sure they’re correct.
I believe Wikious is correct. For instance, an SP class F-70-7 had an overall car length of 53 feet. If modified to have bulkheads, the distance between bulkheads was 48’6".
Normally “length” is interior length, which on a bulhead flatcar would be the distance between the bulkheads. So a 50’ bulkhead flat would be close to 54-56 ft over the end sills. A “40 ft” boxcar is actually 45 ft long.
Use the trains magazine search to look for publish plans.
The SP “50-foot” box car class B-50-47 had these length dimensions: length over couplers 55’8.25", length over strikers 53’2.25", length over running boards 52’6", length over ends 50’8", and length of car interior 49"11.5".
The SP “36-foot” stock car class S-40-5 had dimensions: length over strikers 38’?“, length over running boards 38’5”, length over ends 37’4.75", length of car interior 36’6.125".
The SP “40-foot” gondola class G-50-5 had a length over striker plate of 42’3.5" and an interior length of 40’4".
The SP “40-foot” flat car class F-50-4 had a 44’0.25 length over pulling face of couplers, and a 40’10" length over floor.
The SP “60-foot” coach class 60-C-10 had a coupled length of 68’6.875", length over end sills (inward of the vestibules) of 59’10", with the interior less than that for the wall thickness, say 59’2"?
I don’t have detailed plans for the SP bulkhead flat, but I really wonder if the 53’ flat was then considered a 48’6" car when the bulkheads were added as a modification
It appears that length now always refers to the inside length, with the probable exceptions of hopper and tank cars. Here are some examples from the January 2008 ORER.
I don’t know how “correct” they are, but Walthers has a GSC 53’6" cast flat car, with optional bulkhead ends. I liked the flatcars as-is, so built mine that way:
However, not wanting to wasted the bulkhead ends, I used them on some Athearn 50’ flatcars that I’d “re-decked” with real boards:
Thanks for the link! Wasn’t quite what I needed, though, so I broke down and decided to cheat by buying one at my LHS and taking measurements from there.
