Bullfrog Snot traction-tire maker
What effect will this have on electrical pickup besides no contact on the wheel in question.
Hi Ray,
Obviously, you wouldn’t want to apply Bullfrog Snot to more than one pair of drivers, because those wheels wouldn’t have electrical contact any more. But that would be true of any traction tire. And you don’t have to worry about the thickness of the traction tire lifting other wheels off the rail, either. Bullfrog Snot shrinks down to a very thin layer when it cures. The amount of play built into model locomotive drivers to compensate for uneven track should easily handle that, even on a long, rigid-wheelbase engine like a Decapod. Just apply it to one pair of wheels per locomotive and they should work fine.
Sounds great,…er,might re-phrase that,sounds like it works great. How long does it last before reapplying and does it need cleaning off to prevent lumps of congealed snot building up?
Now if I can just get past the image in my mind that conjures up!
(pictures of holding one’s loco at arms length,with head turned, looking at it with one eye and face screwed up)
How much did you apply for it to shrink down paper thin? Did you run the wheels on the stripwood or did you apply it directly to the wheels like it were brushed on?
Hi Peter,
I put the locomotive in a cradle to sit upside-down and rigged up a couple of alligator clamps to a power pack so I could let it run while applying. I then used the stripwood (only because I couldn’t find the toothpicks) to pick up a drop of Bullfrog Snot and touch it to the rotating wheel. I didn’t apply any pressure, but I did hold the stripwood to the wheel lightly to distribute the Snot. I then let the wheels spin for the next half-hour or so while the Snot started to cure; this ensured the distribution would remain even, rather than sagging to one side of the wheel.
The first time, I applied too little Snot, and ended up with a lumpy, uneven tire that I had to chisel off and redo. Then I read the instructions. :slight_smile: On my second application, I applied a larger drop, which made a bead thick enough to pretty much fill the tread area up to the depth of the flange. I wasn’t sure it would shrink down that much, but it did.
As for its durability, we haven’t run the engines enough to know how long the stuff lasts. The manufacturer says it does have to be removed and replaced occasionally, but it takes so little Snot to do a pair of tires that one jar should last a long time. As for cleaning it off the rails, that’s not an issue. Once it cures, Bullfrog Snot isn’t rubbery; it doesn’t come off. It’s a plastic, with a level of tackiness less than that of Saran Wrap. If you don’t clean your rails often, though, you will find yourself having to more frequently clean gunk the Snotted wheels pick up.
Hope that answers your questions.
How do they name this stuff?
I have some of this but haven’t used it yet. I understand you have to put the loco in a cradle (I was thnking of using a hollowed piece of foam) upside down and then run it for a fairly long time to make sure the snot dries evenly. My question is; do you just sit there and hold the alligator clips or a (kadee brush) on the wheels for a half hour? Is there a better way to just let it run and leave for a while and come back?
Hi Edward,
When I put the locomotive in the cradle, I threaded two pieces of thin wire under the back truck so they hooked over the electrical pickups, then used a rubber band to hold them in place. I attached the alligator clips to those wires. I then applied the Bullfrog Snot to one axle of the front truck.
I have used this stuff for a while and it takes a bit of time and experimentation to get it just right, even with reading the instructions. It really helps on my old steamers, especially since this was my first layout and rather ambitious–problem is–I have a couple of grades that are absurdly steep (lack of experience during layout planning!) and without this stuff I could not get certain locos up the hill without a pusher loco at the end; this stuff helped me overcome much of my poor planning! Although the price seems steep, so little is used each time that I suspect one would never need to buy a second bottle…
This stuff should prove useful to those of us with older, basic locomotives (e.g. Tyco, pre Proto Life-Like, AHM, etc.) whose original traction tires have worn out or have broken off.
So, if you don’t have alligator clips, how would you apply the stuff all the way around the wheel?
Is this product suitable to improve an old dry rubber tire?
I have not tried this stuff yet but the idea is fanastic. I have older models that are hard to find replacement traction tires and wont run well without them. I am anxous to try this out. I will submit another comment when I get results. I am also very interested in how long “Bullfrog” lasts between applications and how well it will fill the flange releif where the old traction tire used to rest. Great Idea!
Can this product be used on O gague locomotives…?
Thanks,
Bob Mclaughlin
Curious to try this product for myself I set up a test on my layout just to see if it worked as well as it claims. I took an average Atlas RS-3 that runs well but can not pull as many cars as I would like to see. I coupled twelve cars behind the engine and sent it towards one of the grades I have on my railroad at a typical speed that I run most of my trains. Sure enough the RS-3 made it up the grade about a quarter of the way then stalled out spinning its wheels and going nowhere.
Taking the engine off the track I placed it into a form cradle belly side up and connected power to the wheels. Turning the power about mid way I took the tip of a toothpick and applied a thin layer of the light green BULLFROG SNOT to one axle (two wheels) of the engine.
I continued to let the wheels spin after the coat was applied and let the centrifugal forces self level the BULLFROG SNOT around the wheels. After about ten minutes I turned the power off and let the engine sit belly side up over night to cure. Important note: If the wheels are spinning away from the point of the toothpick the BULLFROG SNOT will coat the wheels in a nice even layer. If you apply BULLFROG SNOT with the wheels of the engine spinning towards the point of the toothpick it tends to clump up and does not spread over the wheels evenly. A tapered coffee stirrer or a piece of styrene similar to the same width of the wheels may work better for applying BULLFROG SNOT to larger scale engines.
After the BULLFROG SNOT dries the light green color becomes more of a transparent green. In my opinion the 1 oz. jar should last a modeler for quite a while no matter what scale they are applying this to. Now came the real test, I tried pulling the same twelve cars at the same speed to see the results. To my surprise the engine headed up the grade pulling the same twelve cars and passing the point where it had previously stopped. There was no stalling and no wheel slipping whatsoever. I did notice a little wobbling
Now if it just came conductive so it would work as an electrical pickup too.
This is great stuff. I have used it on my Schuco monorail and it is great. The monorail runs much better now. I have also used it on my Fleischmann HO turntable and it made it run better. This turntable is the #1780. The four wheels which supports the turntable had the rubber traction tires wore or missing, I just applied the Snot into the metal groove in layers until I had the right thickness.
Steve Is this product allowed to be shipped UPS air frieght or surface mail only??? Sounds like a goer for those 282’s & 280’s.
& even 2662’s.
Regards
Peter King
I have a Q. What if I put an engine that I aply it to (and let dry as instructions say) in a roundhouse stall and don’t run it far a while like a month or more, becouse of either forgetting it is in there or don’t have time to go down stairs to the layout. Will the snot get uneven and lumpy then? Thanx Tom…
