Cab Forward Big Boy...
As many know I am wanting to “get into” a locomotive and do some kitbashing, wiring, ect… anyways before I get in over my head in Project Big Bad John I thought I’d try something a little less scratchbuilding and more just modifying… so I thought of taking a Rivarossi El Cheapo Grande Big Boy and Cab Forward and make the two into a 4-8-8-4 Cab Forward then detail and paint the locomotive… would you guys agree that’d be something that would be a good first kitbash? I really would like a locomotive not a building or a price of rolling stock…
No, I would not agree. A piece of rolling stock may not be as “glamorous” as a 4-8-8-4 Big Boy Cab Forward but it’s where you need to start. You need to prove you can make modifications on a smaller scale than trying to bite off more than you can chew.
I know that’s not the answer you wanted, Steven, but it’s the truth. Start out simple then tackle more and more complicated projects.
So you suggest,
Piece of rolling stock,
Big Boy Cab Forward,
Big Bad John…
Right?
Am I the only one that sees a pattern here? Evert time this kid talks himself into a corner he changes subjects and starts a new thread.
Here we go again
There are so many things that would have to be done, such as re wiring to get the tender leads enter the front of the locomotive, not to mention trying to create a plausible “front face” for the Big Boy cab, that no, I do not think it would be a good first kitbash. Plus, assuming the workmanship was clean and neat I suppose it could be amusing to see … once. Sounds like a lot of work for the results.
I suggest getting the hang of steam kitbashing with something more narrow and focused. Like swapping cabs, or smokebox fronts, or pilots. Removing cast on domes and replacing with others. That sort of thing, where you have a pretty good certainty that 1) you will finish the thing and 2) the experience will give you the skills to tackle what you want, because without experience you might destroy your raw materials. Believe me that can be crushing.
What el cheapo steam do you have? Sometimes that is the first step in deciding what kitbash to tackle. And not all kitbashing involves radical Frankenstein-like piecing together of disparate parts. I always thought an interesting and challenging kitbash would be to take the AHM/Rivarossi Indiana Harbor Belt 0-8-0 and try to approximate the somewhat similar looking Missouri Pacific 0-8-0 (AHM offered the engine in MoPac paint so at least the tender would be more or less OK).
Years ago Kemtron (I think) offered the raw materials to kitbash the classic B&O “Dockside” 0-4-0T into a cab forward 4-4-0T. (remembering that the “4” pilot truck would be under the firebox and cab). For a long time I toyed with the idea of using the brass casting of the cab forward front from Kemtron to try to make my AHM plastic cab forward look like an earlier class of SP with the flat front for the cab.
I happen to think a more interesting kitbash if you do have an El Cheapo Big Boy and cab forward (I assume AHM/Rivarossi) and the skills,
No, I would suggest putting together the following:
  1. Several (min. 6) more complex rolling stock kits - Bowser, Intermountain, Red Caboose, Proto 2000, Branchline…in that order
  2. A wood laser kit - AMB, Branchline, Blair Line, Bar Mills, GCLaser, etc.
  3. A craftsman kit where you have to size and cut the pieces yourself
  4. Super-detail one item from #1, #2, and #3
  5. A simple kitbash project from styrene
  6. A simple scratchbuild structure from styrene
  7. A medium kitbash or scratchbuild project
After you’ve completed those projects THEN you should be better prepared for tackling a kitbash or scratchbuilt locomotive project. You might need to do several small- and medium-sized projects before tackling what you’ve proposed. Yea, it may seem like a daunting task but you’ll gain a plethora of handskills and experience in the process.
Again, start simple and slowly work towards the complex. You can’t cut corners when it comes to gaining useful and transferable life experiences.
No.
I vote to give him a Big Boy, and a saw, and some CA, and some wire, and some solder, and some paint, etc. Then ban him from the forum until he finishes that project and he posts photos of the result. In the meanwhile we can place bets on the outcome.
Robert
Thanks Tom I’ll work on that…
As far as those who want to ban me please read this article specifically the symptoms of Aspergers… it might help you have more patience…
https://www.google.com/url?sa=t&source=web&rct=j&url=https://en.m.wikipedia.org/wiki/Asperger_syndrome&ved=0ahUKEwiSif-Nv8TYAhVCtFMKHb9tAq4QFggvMAI&usg=AOvVaw3nIgTZemCLO_P-2qQz8wGG
I’m not trying to hide behind my affliction but it’s who and how I am nothing you or I say can change that…
The kid has a name. It’s Steven.
Yes, he goes round and round with multiple posts and new ideas all the time. On the flip side, some of them turn into decent discussions about other topics that pertain to Model Railroading.
When you’re on the sub-forum browsing topics, you should see a line similar to this under each topic’s heading:
" Posted 1 hour ago by (USER NAME) "
If his topics annoy you, you can ignore them when you see that he’s the one that started them.
But by rights, he’s following the rules of the forum.
Steven, this is very good advice. Please listen to Tstage on this. Until you have assembled the more difficult plastic kits you really have no idea what you are getting into.
This makes it difficult to post advice that is helpful, because you really have no idea how much you don’t know and the skills you need to develop.
Please answer this question: Have you ever drilled two #78 holes into a plastic freight car and installed a wire grab iron?
If you have not even done this yet, please don’t ask about difficult kitbashes anymore. You really need to get some perspective on the topics you are discussing and you can only get this perspective by building.
-Kevin
Thanks for the article Steven. Very informative!
We have a club member who has Autism. He is a great guy! He does have his specific interests of course, but I find it very interesting to listen to him. He knows more about Public Transit buses than the guys who built them![swg] We are fortunate in that almost all of the club members accept his situation and treat him well.
As for the nay sayers, you already know how to deal with them. You don’t need my advice.
Dave
Here’s an analogy. Saying you want to tackle these sort of projects as a first project is akin to saying that you want to get into playing quarterback by playing an NFL playoff game. These are huge projects with enormous experience requirements. I’ve got a few years experience plus leftover childhood model building skills and just cutting down some refeers to add the truck style refrigerator unit and fuel tank is still a bit of a challenge. I wouldn’t attempt something that requires troubleshooting and design work like these fantasy jobs.
This was all covered in the other thread. Starting with a huge project was a bad idea ten days ago. Starting with another huge project is a bad idea today.
MR has published a ton of simple kitbashes over the years; things like Eric Boorman’s article on kitbashing 40 foot boxcars into 50 foot.
Start with something like that.
Would a Walthers Cornerstone kit be a good start? Or still jumping the gun?
I was thinking either the Brick Mission Style Santa Fe Depot or the Valley Citrus Packers…
Hi Steven:
Have you built any kits before? If not, then I think you are still trying to be a Master Equestrian before you have even sat on a horse. No insult intended - but you are setting yourself up to be disappointed and frustrated IMHO. I haven’t built the Mission style Santa Fe Depot but I can see that it will require some careful assembly to get all the detail pieces installed correctly.
The other problem with building a structure kit is that it won’t give you the experience that you will need to do the sort of locomotive kitbashing that you envisage. If you want to be able to cut locomotive and passenger car shells up and then reassemble them then you need to practice cutting straight lines in car bodies, sanding edges square, applying fillers, adding details… etc. etc…
I would refer you back to the suggestion made to start by moving the cupola on an Athearn BB caboose from one end to the middle of the caboose. Once you have done that, the same caboose could be used to learn how to replace molded in details like grab irons with real metal ones, install real wood walkways, install proper caboose trucks (I can’t remember if the BB caboose trucks came with leaf springs or not), maybe blank out some windows, upgrade the brake wheels and stove pipes, upgrade the handrails…you can go as far as you want. The point being that it will give you a taste of what kitbashing really involves.
I don’t know what tools you have already, but if you are going to do any of this stuff you will need a selection of tools. If you let us know exactly what the project is that you want to start with, then we can give you a list of the tools needed to do the work.
Cheers Steven!
Dave
Make sure you remember to move the throttle linkage to the other side of the boiler. When rear becomes front, left becomes right.
I’m blessed with five grandsons. One was diagnosed with Aspergers some years ago. He is also the one who really loves model trains, even now as a young adult making his way in the world. It still pains me to recall the days of him being bullied when all he desired was what all humans desire, acceptance, patients and respect.
Sincerely and with respect, Peter
When I was young, as in high school, and new to model railroading, I had some pretty lofty 'bashing goals, and jumped in with both feet. I created a lot of model carnage. And in retrospect, even if I had pulled off the mods as planned, (and sometimes I did) they would have been, and were often rather goofy looking to more educated eyes. As in my own, later. I learned “just because I could doesn’t always mean I should”.
This is only to add experienced emphasis to what the guys are telling you above.
One area where you can believably get away with some radical kitbashing (and imagineering) is in the area of small industrial locomotives. Quite a few geared steam locomotive drive trains, for example, either in 1 or 2 truck configurations , got put to use under diesel or gas powered locomotives with all kinds of odd body and cab configurations. Usually done in the home shops. Lots of pictures on Google. Search “locomotive critters”.
I would tend to fear, as eluded to above, that the novelty of a 4-8-8-4 cab forward, after all that work, would wear thin pretty quickly, even to you. But, hey, it’s your railroad, as they say.
Perhaps if this satisfies your ambition to modify big steam, SP did make some big articulated rear cab 2-8-8-4s, AC-9, basically cab forwards turned around. These were never released in plastic, only limited brass. So they don’t get modeled too often. And I personally think they are among, if not the most beautiful heavy articulateds ever built*. So it would be fairly unusual, yet totally prototypical. Interesting story behind them too, allowing for some plausable imagineering.
Channel that wonderful enthusiasm of yours into projects with staying power. You’ll know what I mean later if not sooner. And again, save the big stuff for when you have some practice under your belt. Dan
OK, guys, these replies are all getting very circuitous. All of these comments and suggestions have been made many times before, to no avail.
I suggest a different tact. Let’s agree with Steven and encourage him to tackle a project that he wants to tackle. I will fire the first salvo.
Steven, by all means, take on this project. Get hold of a Rivarossi Big Boy and a Cab Forward and get to it. I, for one, would love to see the results. Truth be told, it would be a good kitbash. Yous seem to have the smarts and the technical knowledge to do it, so go for it. Report back to us frequently with photos and updates.
I am truly and sincerely looking forward to this project, and I await the first update.
