Looking for part 610-7606-100 smoke unit replacement. Or if anyone knows of an alternative part to replace this smoke unit for a NYC CABOOSE. Thank you
Sadly, “NYC CABOOSE” and the part number is not quite detailed enough. A little more info would be helpful: What brand? What year (if you know)? What scale?
It’s a Lionel caboose Lionel part number 6107606100. NYC caboose with light and smoke unit. Looking for smialar
Hmm. Does the shell look like this, excepting the paint scheme of course?
If so, then we’re a little closer to finding the part but not there quite yet.
Going on the Lionel Support site shows the smoke unit for those cabooses is out of stock. Searching the Trainz parts site brings up a lot of smoke units but none for the caboose. What the OP likely needs is a similar size and rating smoke unit that can be modified to work in the caboose.
That’s what I’m looking for, but first I need to find out all of what is needed to start with.
Try Hennings Trains in Lansdale, Pa.
They have a website where you can get phone number.
Welcome aboard Dagobbies!
If you’re looking for a replacement smoke unit for that caboose try the following:
https://thetraindoctor.com The Train Doctor
https://ttender.com The Train Tender
https://trainwx.com TrainWorx
If they don’t have a Lionel original replacement you’ll have to try a substitute. Seuthe makes an assortment of smoke units that can be made to fit. They’re available in different configurations and from different sources, Google “Seuthe Smoke Units” to find them.
Good luck!
Welcome aboard Dagobbies! ![]()
