Could anyone recommend some CAD software that would work well for drawing up scale plans for building construction? There are a number of prototype buildings I am interested in modeling. I could draw the plans up by hand, but it seems that using CAD software would be quicker and easier. I would like a simple CAD program where you can set the scale (1:87, 1:160, etc.) and after drawing the building in standard 3 views, you could print it in the correct scale.
So far, I have not found anything that would work to my satisfaction. Thanks for your help.
I have been trying “Solid Edge”. It’s a free demo of a professional CAD program, lots of power, 287 megabyte down load. Google will take you to the home page. It ain’t easy to use, I haven’t finished my layout drawing yet. I have been unable to create true scale drawing hardcopy with it. My scale drawing are coming out 20% small. Documentation is thin. They do have a news group. I’m fairly computer savvy but not an experienced CAD user. I’m about to give up and go back to architect’s scale and Pentel pencil.
There is a family of programs by “Punch!” (maker of Super Home Suite) that might suit your purposes. The mid-range programs and above offer an option of “scale models”. I remember 2 of the options were 1:48 scale and 1:87. You select the thickness of the foamcore board you want to use and the program will print out all the faces of the building with proper tabs for assembly.
The main focus of this program is home design; it isn’t limited to those options. I’ve drawn a few stations and lineside buildings just to see if it would work. Your mileage may vary, et al. I bought my copy on ebay. You can also find it at Wal-mart and Best Buy.
I have used TurboCad by Imsi for over 15 years for all purposes, including modeling prototype buildings.
Rather than draw in your scale, it is much easier to draw in real world dimensions which saves having to convert every one to scale size. The print module allows printing to any scale size, i.e. 1/4 inch/foot for O gauge. I forget the actual fraction that I use to print in HO but it is a function of the relationship of 87.1 to a foot. It is close to 312/64ths. I print a draft copy and then use a scale rule to verify the dimensions. If need be, I add or substract another 64th or so to get a dead on print. Another advantage over hand drawing is that you can design one window and copy and paste it onto construction lines where needed. Same with doors and other similar items. Clapboard siding, draw one and then specify the number and spacing, Bam again.
When done, I print a copy and then using photo mount spray I mount it to cereal box cardboard and assemble it to verify the fit. To build a mockup to place in my mockup module, I make a file copy of the drawing and then color it. You can design any color to match the prototype and texture brick, shingles or whatever.
The least expensive version is more than suitable for model railroad purposes.
As a side note, I use it to design brass car sides. Draw a window opening, copy and paste multiple copies, specify the number and spacing, hit enter and BAM! All of the windows. Rivets are fun. Draw one rivet and specify the number and spacing and BAM, the whole row of rivets. If there are too many, just delete the overs. I can draw a HW parlor car side in about 15 minutes. Then I can make a mirror copy and do the other side. Just move a window and door or two, and I’m done.
