SCALE speed doesn’t change just because you choose to use a fast clock. All the fast clock does is make our midget main lines seem longer and shorten a day’s worth of operations into something a crew can handle between lunch and dinner.
For you HO-scalers, here’s a real down-and-dirty:
In 1:1 scale, 60MPH is 88FPS. Therefore, 60 scale MPH is 1FPS, well within standards for speedometer error. One inch per second = 5 HO scale miles per hour.
My own computations are metric, to a scale used only by those who model Japanese prototype. I won’t bother you with the details.
Chuck (modeling Central Japan in September, 1964 - 5:1 scale time, 2.5m SKM)
Speed is a function of time. By altering ‘railroad’ time, you need to include it in the formula to equate it to real time… don’t make me get all Einstein on your arse. [swg]
I have another perspective to this question: What if you use “Smiles”? This was the term for shortened scale miles to give the impression of a longer mainline. I use these on my layout, where the mileposts are about 500 scale feet apart. That way, I can run mile long trains that fit in my sidings - using about 10 cars! If I used real scale miles, my mainline would be around a mile…
You don’t have to, “Get all Einstein,” on this long-time technocrat. You just have to realize that the scale time ratio and the scale distance ratio are supposed to be the same - and thereby cancel out (since your distance/time in full scale computation becomes R x distance over R x time, where R equals the scale time, scale distance ratio.)
Using Frank Ellison’s 12:1 scale time ratio, your formula would have a model loco running at 5 scale miles per hour. Even if your intellect was telling you, ‘It’s doing 60!’ your unmodified eyeballs will be saying, ‘I can jog faster than that!’
Wazzamatter? Too simple and straightforward for you?
Ever hear of the KISS principle? Try it, you’ll like it.
Chuck (modeling Central Japan in September, 1964 - and running at scale speed)
a 1:1 scale vehicle going 1 mile per hour moves 1.467 feet per second. this is a standard. so 30 miles per hour is 44 feet per second, 60 miles per hour is 88 feet per second and so on.
a 1:87 scale vehicle is moving 1.467 scale feet per second at 1 mile per hour. 50 miles per hour will be 73.3 ho scale feet per second.
