Can someone answer some questions about DCC?
I’ve been using DC on my layout forever now and I’ve thought about making the switch to DCC since the locomotive I’ll be getting is equiped with DCC Digitrax. I have no idea what I need to get besides the decoders and the basic hand held throttle, it seems like I need to get other things in order to run DCC. Then I need to figure out how to put all that together. [xx(] Can somebody help me with my questions, it would be appreciated.
Hi;
First read this:
http://www.dcctrains.com/tonystips/dccprimer/index.htm
Then give Tony’s a call to discuss your desires.
http://www.dcctrains.com/contact.htm
If you want to e-mail my off-line I will be happy to respond to questions after you have gone through the primer above.
2059,
In order to get an overview without getting overwhelmed I’d recommend getting “Digital Command Control - the comprehensive guide to DCC” ISBN 91-85496-49-9
It gives the principles behind DCC and compares some of the systems.
Basically what you need is:
a) Command station (they come in all kinds of sizes rated in output Amps)
b) at least one cab (depending on mfg very simple to very sophisticated)
c) one decoder for each engine
In addition you can get accessory decoders (for turnouts etc.), computer interfaces and… and… and…
There’s tons of stuff, but the first three will get you running.
When looking at a DCC system, keep in mind that you probably will expand it sooner or later. So also check for upgrade path and expandability (those two are not the same!)
I (re)started my N-scale layout after many years of being off-line. I went for the MRC Prodigy system and I am VERY happy. It works well, allows you to also run accessories (i.e. turnouts, building lights, etc) from the same “brain” unit. You do need different controllers for some of the different options. I would say I’ve spen around $500 for the system, extra handhelds and enough accessory decoders to work all the turnouts (12 or so) as well as a few decoders for the trains. I’ve been using the Digitrax decoders, as they are easy to install. I have a few wierd problems, like some of the loco’s continuing to respond to the DCC comands even after another loco is selected. I chalk it up to my own learning curve.
Good luck!
If your running straight DC now (no blocks) its a matter of connecting two wires up to your layout from your DCC system. I made the jump 5 years ago, and if I can do it anyone can. The only hassle is installing decoders in older loco’s, and that isn’t hard once you’ve done one. The newer loco’s are mostly plug-ins now. The benefits far outweight the small hassle. Then of course theres the benefit of sound. Once you switch you’ll wonder why you didn’t do it earlier.
Thanks for all the help. Now I found with the info you all gave I’ve got AC right now. That’s running the track on a power pack right? I’ve got a big MRC power pack with like 3 or 4 electric connections to the track throughout the layout. This might be a future project of mine when I move out of my parents’ house. I’m 20 and in college right now, money is tight and my parents always watch how much I spend. Thanks again for the help!
thanks for the info even though i did not start it.
