Can you glue plastor of paris?
I need to know if you can glue 2 peices of this together and if so with what? Thanks Baker
Yes,
White glue, yellow glue, adhesive caulk, plain caulk, florest glue, epoxy, construction glue - almost any glue with a little bit of body.
CA works BUT it will seep in and you will need a sealing coat on both pieces before attempting to glue together with the gap filling type. Too time consuming and wasteful for me.
Karl
[#ditto]
There is all types of cements and glues you can use…
You should also be able to use spackeling compound on small cracks.
For large brakes use scupture mold.
Don’t forget just plaster to plaster. It depends on what you are doing. If it’s a repair to some broken plaster part, go with glue.
If you are attaching a rock mold to hardshell, plaster works fine. Start by wetting both surfaces well with water from a misting bottle, then trowel on a semi-stiff plaster mix and push the mold into the plaster. Any excess that oozes out around the mold casting can be trimmed off, then carved to match what’s going on in nearby scenery.
Gorilla glue should work just fine it isnt the cheapest thing but it works great just dount use too much it foams up REALLY STRONG
Gorilla glue should work just fine it isnt the cheapest thing but it works great just dont use too much it foams up REALLY STRONG
