Can you put a turnout on a grade?
Everything I’ve read here seems to say no, but it the approach, normal and diverging route are on the same grade, does it cause a problem?
You can put a turnout on a grade as long as the grade doesn’t change for one car length on each side of the turnout.
+1
I’ve never seen anything posted here (from a reliable source) that suggests that a turnout cannot be located on the grade.
+2
I have a double crossover on a grade.
I don’t know about never, but I have seen a lot of caution expressed abut locating turnouts on a grade. I suspect that a lot of that is the Voice of Experience and I don’t mean good ones.
It will work, provided you provide enough transition and vertical curve smoothing so that it doesn’t cause problems. If everything is on the same grade going the same direction is easiest. It’s when there’s a rise followed by a decline or vice versa where things get dicey. If you already have worked out what vertical curve transitions work for your needs, then doubling the length of such compensations, is probably a good rule of thumb.
If you aren’t sure what a vertical curve or a transition to or from it is, then look that up as it’s a concept vital to understanding how to make this work smoothly for you. The easiest way to see this in action is to watch how couplers rise and fall in height and relation to each other above the rail over changes in grade.
I have a turnout on a grade, about a 1% grade. the through track follows the grade of the branch line, and the diverging route track go to a pulp wood loading area.
I haven’t had any problems with it, but it is on a switching spur, not on a main line.
Mike.
What Carl425 wrote…
That’s what I remembered, but with some of the problems posted here, I’m sure some put vertical kinks on every end of their turnout plus unintentional superelevation.
Thanks for the info, everyone.
I would make that your longest locomotive length on each side of the turnout, particularly if you run steam with long wheelbases.
All three of the turnouts shown below are on grades…
The two tracks at left rise as they approach the camera, while the track to the factory drops at the same rate, then levels-out.
The track at right is rising as it approaches the distant turnout, and the points-end of that turnout is higher than the end closer to the viewer. The low point of the “dip” on the main occurs adjacent to the closest boxcar on the factory’s spur.
All of the up and down track here is to allow a medium height just beyond the distant curve, as that’s where the line splits, with one going to the lower level of the layout, and the other to the upper. That starting point allowed me to keep the grades to a maximum of 2.8%.
I have several on grades, both curved crossovers and yard turnouts.
A practical matter on the yard off of a mainline grade is that typically one wants the yard flat enough so the cars don’t move on their own, thus it is important to allow for the vertical transition mentioned above; i.e., accommodating the slope difference between the flat yard and the mainline grade. The transition eats into the useable yard length for cars that don’t move on their own.
I have an #8 or #10 on a grade where my main line goes into two mains. I also have a curved T/O on a grade and never had an issue.
[C):-)]
