New to this, go easy on me… ![]()
A friend sent me a Bachmann 2-8-0 and two tenders. One was an SP Vandy tender with a DCC and sound card in it. When I operated the loco + tender on DCC you could hear the motor spinning (turns out the nylon gear on the motor was cracked) and I could get bell, whistle, and hear steam chuff.
I had to get some parts and redo the loco. While I waited for parts I moved the DCC/sound, plugs, etc into the other tender, a coal type tender.
Then I screwed up. I put it on the program track, read the decoder, picked something, set a new long address, then went to the sound volume tab and turned it up to full volume, and then saved every page out to the loco. Pretty much wrote over the top of anyting that was there. The loco will run, but no chuff/bell/whistle. F2, F3, etc. can produce coupler clank, pop-off (?), some other sounds.
I Googled the heck of it… I tried all of the Soundtraxx Bachman OEM and Bachmann Sound Value options under the Soundtraxx folder. The loco runs on all options, and I can get accessory sounds on some of the function keys, but never chuff, bell, or whistle. I have checked on all those option under the sound tabs in Decoder Pro and there are options for all of those listed.
By the way, when I use DecoderPro to try to read the Decoder (CV8, etc.) I get nonsense results and it says it is unidentifiable and there are several options: Athearn diesels, BLI diesels, N scale stuff, etc.
Looking at the birds nest… there are a lot of heat shrinked solder connections. Maybe this card is an upgrade to the standard Bachmann gear?
It would be great to find the correct DCC/Sound decoder profile for this card!
Thanks,
-Richard
