Railroads, like highways use mileposts to measure distances. Subways on the other hand require a more precise measurement because trains are shorter, more frequent, and signals and other wayside structures are closer together. A surveyors chain is 1000’ long. Since selective compression is required on a model railroad, I am using a chain that is 500’ long, or 5.74 feet using a Stanley tape measure.
I made a train 5.74 feet long to use as my measuring stick and dragged this around the railroad making my measurements.
Line A is measured from the south end of the Chambers street station in a northerly direction.
At marker 23 Line B branches off of it, while Line A continues to marker 45 at the north end of the 242nd Street station which is the end of the line.
Line B is measured from marker A23 located at the south end of the Smith 9th Street station as it loops through the hidden tracks and back to the south end of Chambers Street at marker B14.
Line C is measured southbound from the south end of the Chambers Street Station (marker A0) and goes around the loop at the South Ferry Station returning to Chambers Street at marker C9.
From Marker A 0 to marker A 23 is a distance of 11500 scale feet, or just over 2 scale miles.
From Marker A 32 to marker A 45 is a distance of 11000 scale feet or just under 2 scale miles.
From Marker B 0 to marker B 14 is a distance of 7000 scale feet of over one mile.
From Marker C 0 to marker C 9 is a distance of 4500 scale feet or just under one mile.
From Marker A 0 to Marker A 23 the railroad runs on a four track main line.
From Marker A 23 to Marker A 45 and from Marker B 0 to Marker B 14 the railroad runs on a two track main line.
From Marker C 0 to Marker C 9 the track is measured as if it were a single track line.
A train running from 242nd Street to South Ferry then covers about 25000 scale feet, or about 4.5 mil
