Classic Train Questions Part Deux (50 Years or Older)
Ownership question: Who was the actual owner of South Shore’s Illinois trackage from Kensington to the State Line and what was the arrangement under which South Shore operated this trackage?
Kensington & Eastern - Leased from IC by CSS&SB
Mark
I’ll give you the answer but the arrangement is a lawyer’s and accountant’s nightmare. The line was owned by Kensington & Eastern, a 100% owned subsidiary of Illinois Central. K&E leased the line to Indiana & Kensington, a 100% owned subsidiary of South Shore. I&K sub-leased the line to South Shore for operation. Source of all of this is a Moody’s Transportaion Manual from the 1970’s.
KCSfan, your question.
Not long before WW2 two railroads teamed up to run a through interline motor train. This was an odd service to be introducing at the time. One of the railroads was family owned and a member of that family was appointed Receiver of the other road in 1939. Name the two railroads and the end points of the motor train route.
Mark
Were either or both or these railroads either Pinsley or Salzburg properties?
No, but you’ve got the right idea. They were often referred to as xxx railroads or properties. xxx being a family name.
Mark
I’m going to guess the Muskogee Lines. Midland Valley-Kansas-Oklahoma & Gulf, between Witchita, Kansas and Denison, Texas.
No. At the time of this question there was no longer passenger service on either the Midland Valley or Oklahoma City Ada Atoka. However the KO&G did still run a motor between Muskogee and Denison.
Mark
A hint to ponder.
The end points of this train’s run were just under 75 miles apart.
Mark
If you started a trip on this Motor train you had a combined total of eight named trains you could continue on to destinations in Florida. However many of the connections were far from ideal with regards to timing.
Mark
If you wanted to go north instead of to florida, you could take these connecting trains to places like St. Louis, Chicago and Detroit.
Mark
Too busy right now to do research on the internet, but I believe this doodlebug train might be a combination of two of the three: Atlanta and West Point, West Point and Westerm (or Eastern?) Alabama, and the Georgia Railroad. Atlanta is probably one end, or maybe even a middle, and possibly Augusta as the other end?
Time to give this one a try… Georgia Northern and Georgia, Ashburn,Sylvester and Camilla, from Boston to Ashburn via Bridgeboro. That would give you the PRR/L&N/ACL South Wind route at Boston (GA), the IC/CofG/ACL City of Miami/Seminole route at Sylvester and the NYC/SOU Royal Palm route at Ashburn.
Connections to St. Louis , Chicago, Detroit, Cleveland and all Florida points.
One of the roads you mention is correct but the other one is wrong . The motor train did not serve Boston, Sylvester or Ashburn. You have named some of the nine trains it might connect with, none of the places where these connections could be made are correct.
Mark
rc is obviously a lot close to an answer than I am, so Iwill be interested in seeing him make a second try and assume it will be correct.
Assuming the partners to be the Albany and Northern and the Georgia Northern, I get the Royal Palm , the KC-Florida special and Ponce de Leon at Cordele, along with a couple of trains routed via the AB&C. At Albany I get the City of Miami and the Seminole, and at Moultrie some west coast trains that I don’t have a list of that were headed for the Perry cutoff.
You’ve got it now Rob. Motor trains No.'s 1 & 2 ran between Moultrie and Albany on the Georgia Northern and between Albany and Cordele on the Albany and Northern. At Cordele connections coudl be made with Dixieland (AB&C) and the Royal Palm and Ponce de Leon (SR). The KC-Fla Spcl ran via Jessup and not Cordele. Circa 1937 connections at Albany could be made with the Dixie Flyer, Dixie Ltd, Southland, Flamingo, Seminole and Floridan (CoG/ACL).
Lookking forward to your next question.
Mark
In the great Pennsy re-electrification this road number was applied to three different engines.
The number is 4899. The first 4899 was a GG1 which was re-numbered to 4800 after the Claymont tests. The second 4899 was an R1 which was re-numbered from 4800 at the same time. The third 4899 was a new GG1 from subsequent construction. The R1 was again re-numbered to 4999 at that time.
Absolutely correct. And on the way by you got the engine that had three numbers…
