Doesn’t GE have some sort of a system for naming locomotives? I always thought the “9” meant it has significantly newer technology then the "8"s, the “44” is the horsepower in hundreds, the “C” means it has 6 axle trucks, and the “W” means wide cab. It does not seem to me to be the same procedure for naming a baby.
You have a point, but my point is that except for the “U” in the U-boats and the dash, all of the characters have a meaning, even though the C went form 6 axle to current. I do seem to recall the U meaning Universal. Is that correct?
This is from memory, so I’m not 100% sure…
The first DD35 were booster units (I believe that EMD built a demonstrator set with two DD35 between two GP35, for a total of 15,000 horsepower, which is what Union Pacific’s operating people thought they wanted). A year or two later, U.P. asked for some with operating cabs: they were called, to distingui***hem from the earlier B-units, DDA35.
When EMD introduced its “40” series of 645-engined models in 1966, the catalogued a DDA35 lookalike called either-- I don’t remember which-- DD40 or DDA40. No sales. After a few more years, Union Pacific ordered a modified-- bit larger, wide nose, various technology updates that eventually went into the 1972 “Dash 2” line, engine rated at 10% more power-- version, which I’m pretty sure was called the DDA40X: DDA for a cab-equipped DD, 40 for its 16-645 engines, X for the new features ad semi-experimental status. They were delivered in 1969, the hundredth anniversary of the completion of the transcontinental railroad, so U.P.'s p.r. people dubbed them the “Centennial” class.
The Universal line from GE actually predates the U25B by several years. It was originally applied to GE’s export designs which came out in about 1956 to replace the prior shovel-nose designs, some of which had 244 engines.
