Most of my life was spent at sea and now I would like to do some railroading.
I have about 100 pounds of old Lionel track (nothing newer than 1954) and I would like to clean the good sections up. I was thinking of purchasing a buffing wheel to polish all the rust off the tracks.
Is this a good idea or is there a faster way. At 75 time is catching up with me and I would like to get started.
Hey Jack…just how clean are you wanting the track to be? nice and completly shiney like new, or just where the wheel hit the track? Unless the track has more than surface rust, I usually just clean the top myself. Some fine emery/sandpaper works fine. Or there are special pads that do the job. never use steel wool, small particales will get into the trains. Get some of your favorite beverage, something good on the TV, and do a bit at a time. It’ll go pretty quick.
I have a fine brass bristle wire wheel 4 1/2" I think, mounted to an old furnace blower motor, operated with a foot operated switch to clean track. The good thing with American Flyer track it only takes 2/3 the time to clean.
If you have a Dremel motor tool, you can use the carbon steel wire brush wheels to do a very good job with the worst parts. Then a Scotchbrite scouring pad rubbed across the rail surface should render a fair amount of the track useable. The Dremel and Scotchbrite are also useful for cleaning the track pins. Only you put the pins in the Dremel chuck and spin them at a low rpm against the pads. They shine up beautifully!
And [#welcome] aboard! This is a very laid back and informative place!
If the track is physically dirty, put it in the sink with water and dish detergent and clean with a mild brush. Don’t damage the insulators between the center rail and the metal crossties. Dry the track quickly and completely to avoid rust, using heat if necessary. Rub it on top with a rag dampened with paint thinner or mineral spirits. Finally, rub on top with a Scotch Brite pad. Check the pins for tightness and remove rust if necessary, and use needlenose pliers to tighten and shape the track ends.
You didn’t indicate what condition it is in, so it isn’t easy to give one simple answer. First off, NEVER use sandpaper as suggested in one response, and the same goes for Steel Wool. Steel wool leaves tiny pieces of me al, which causes short circuits. The sandpaper removes the tinning from the rails, if you get too aggressive, which will increase further rust later on.
If the track is primarily in decent condition, a “Scotchbrite” pad can clean off the top of the rails, which is the critical area to get attention. If the track is fairly rusty, the quickest route would be “Evaporust”. Get a small tub, fill with evaporust, and place the track in the solution. Evaporust is ‘biodegradable’ so that isn’t a problem. Soak the track for at least 24 hours. Remove the track, rinse them off, and make sure they dry out completely. The insulators on the center rails, has to be 100% dry. The wire wheels on a Dremel, spread little tiny pieces the fly everywhere and stick in clothin. A larger wire wheel in a standard drill will do as good a job, and the major area to clean is the tops of the rails, where the wheels touch. The sides of the rails don’t touch the wheels for the AC is needed for the train to run.
Choose the best option, for what condition the track is, and have a party!!
If the track is rusty, I think the plating is already gone.
I have built layouts using old track that was rusty and cleaned, and brand new track. In my experience, the old track will be rough and pitted, causing lots of sparking on the center rail, and lots of drag / wear on items with sliding shoe collectors.
I will not use old track that was rusty and cleaned.
Dirt is one thing, rust is another.
Ahoy and thank you so much. I just want to have the top clean so that I will have good power flowing. The sides being rusty is about what I see on the short lines here in Texas.
The track is in good condition considering it’s age. It has some surface rust, yet is not pitted. I am going to clean it as suggest on the forum and see.
As my train room is 40’ x 80’, new track would cost well over $1,000.00 which I am not in a position to fork up right now.
LL has some good ideas but here is the simple dope,
Keep in mind that dirty rusty track looks more realistic than shinny new track. You really do not have to go overboard (pun intended). If I must clean I use an SOS pad to clean just the tops of the track, (admittedly a bad idea and a scotch bright pad is smarter).
If the track is totally shot just toss it. At 75 life is too short to waste time detailing the track. Plenty of used but clean track out there to work with.
I found the Evaporust to do a great job. What I do to make sure it doesn’t take the black finish off the ties though, is I take the sections apart, and clean the rails. If the ties are too rusty to simply be scotch-brighted, throw those in too. But you’ll have to paint them afterwords. I also have a ton of rusty track, in my case, mostly a bunch of Flyer I got dirt cheap, and I’m taking it bit by bit. If I’m lucky, they’ll all be clean sometime in the next 3 years, the way I pile up my projects!
I agree that I want to keep the sides of the rails a rust color.
I wondered if I could just purchase one of the large buffing wheels that mount to one of my work benches and then, using different compounds, buff the entire section of track with a very few passes and almost no effort. You thoughts, please.
I will purchase the Evaprorust during my next trip to town and give it a try.
I had thought about purchasing one of those large, dual wheel, bench mounted buffers and, using different compounds, clean a section of track with just a few passes and very little effort on my part. You thoughts?
I know I’m late to the party on this one, but my personal thoughts, with 800+ sections myself:
if the track is so rusted that some quick passes with maroon scotchbrite (for metal work) won’t clean it up - FUHGETABOUTIT. Used O/027 track is way too cheap and plentiful to spend much time cleaning it up, unless there’s some particular sentimental reason for it. Evaporust does work for rusty stuff, but you gotta be careful and not lose track (pun intended) of time - soaked some old wrenches and sockets for too long (got sidetracked and forgot 'em) and now they look and feel like absolute crap and don’t want to clean up.
My preferred method:
quick visual inspection to separate the usable from the twisted/trashed/rusted
get a jug of Greased Lightning, mix w/ water at prescribed ratio in a large tub
dump in a pile of track to soak for a short time
quick scrub w/ brush of your prefered comfort/style to remove grease/grime
thoroughly rinse off, and thoroughly dry (I used a separate room with a wall heater cranked up, or the oven up just enough to warm should work)
a quick continuity check to ensure the center rail is still isolated
get a box or few of 3M Scotchbrite maroon pads 07447 from Amazon (cheapest) or your local parts store (pay throught the nose). They call this the “general purpose” pad but I remember it as the metal/brightwork pad. If less than a minute of quick passes with this pad (wearing gloves) doesn’t give you a dressed up rail top/upper side, then your tolerance for rust at the beginning visual inspection step is far greater than mine…
