This is really one of the reason I have try to not use often airbrush and really lost the taste to use it.
It was always a clear nightmare to clean it after use and this is particulary true with the use of acrilycs paint.
This has been already mentionned in other topic, but after a while I make the step
I ended by a solution which keep me back happy with the use of an airbrush.
Seen on Amazon I buy two years ago a small ultrasonics cleaner; this stuff is used to clean jewels basicaly, but it clean an airbrush like a never used one .
It’s very easy to use, and no matter if paint is dry on parts of the airbrush, any particules go out when the parts of the airbrush are put in the bath.
I use just distilled water and a few drop of detergent in the bath, 10 minutes and voilà a clean airbrush.
I just need to dry the parts and bring back them together.
Yes it’s a small investment, but I don’t regret it in any way, I just regret to have not do it earlier.
Yes I forget to mention, the nightmare is gone, and I have a lot of pleasure to use my airbrush often even for a small spot of paint; before this needed reflexion because all the work I need backward to clean the airbrush.
And my beloved half use it too…she is happy to use it for his jewels.
But one solvent not often mentionned which eat all paints even acrilycs is “thinner cellulosic”, this thinner is used as a solvent in many paints and often for car paint
It’s extremly volatile but disolve any paints in a few second; take care of plastic he eat styrene too; I have used it a lot for professionnal use but also for lacquer paint in modeling use; it dries quickly and feel it more performant than acetone.
But use it in a well ventilated area this solvent like acetone is volatile and fumes are I believe …somewhat toxic…
