I have an HO diesel engine that I’m trying to get running again. I’ve isolated the problem down to where to electrical contacts are suppose to touch. One part looks oxidized (copper i think). What can I use to clean it?
Hello All,
There are many electrical contacts on an engine depending on it’s type and manufacturer.
Which specific contacts are you referring to?
Are you dealing with a steam or diesel engine?
If you can narrow down your inquiry it would help.
Hope this helps.
An ordinary pencil eraser can get a lot of crud off things like battery contacts. That’s a good first stopgap attempt.
Radio $hack used to sell spray contact cleaner. I don’t know if they still do. There are still a few of them scattered around the country.
I’ve had good luck with this. It will not damage electronic circuits or boards, and it will clean electrical contacts almost instantly without effort. I got this in Walmart auto section:
I have never tried it on model trains but that was one of the uses of WD40. I have used it on Ford trucks when the distributrer got wet. Try it at your own risk.
. I’m picturing in my head an old Bachman split frame diesel with the bronze contact bars under the frame or an Athearn with the shiny metal strips. A pencil or better yet pen eraser would be my first choice.
Pete.
I would not spray anything on my locos. What type of loco are we dealing with?
Simon
