I have a Climax A that I gussied up a might, and I really like it. Once, I paid a guy who was supposed to be a Climax whiz to smooth it out, and it did run really well…but it still sounds like a coffee grinder chewing on walnuts.
[EDIT – note that the following applies to a Climax, and not the Climax A he has, which I only remembered after the fact as being externally a boxcab with pretensions. Fixing the locomotive he has isn’t nearly as involved…]
On a normal Climax, you are having to backdrive a fair amount of motion to make that jackshaft turn and crossheads shuttle, etc. These are not gears ‘settled’ into a continuous load, and neither fabricated nor lubricated like those in a helicopter transmission…
start by disconnecting and removing, as far as possible, the entire visible powertrain from the ‘quartered cylinders’ and get the electric drive to the wheels aligned, ‘lapped in’, lubricated, etc. Then put back any dummy shafts or gears and debug them. That will get you to the jack shaft arrangement and it may take some careful adjustment or even redesign to have this run smoothly when backdriven (or ‘coasting’ if it will do that as built…)
Got one andI love it. Right now it’s doing switching duty in the mill yard, but only until I get another engine–maybe a 4-4-0, and it joins my Shay in logging duty. The Climax brings down ore from the mine to the refinery.
Either the Bachmann 44 tonner or 70 tonner drive fits inside the MDC boxcab diesel, and the Climax is just a Boxcab with some different bits kitbashed on by the factory (an article in a 1974 or so Railroad Modeler (yes, that’s the correct name of the magazine) had the originals, actually done by grabbing some parts from the MDC inventory and bashing it together.
If plastic gears, there’s not much to be done, except perhaps the alignment that overmod suggests. If there’s brass to play with, first I’d isolate or remove the outer doin’s so that they are still, and then run the locomotive to see if the drive is what’s making the noise. If it grinds, and it’s not plastic, or if it doesn’t just need alignment, you can try a lapping compound. I recall we talked about Pearl Drops back in 2005 when I first joined the forum. I think I’d prefer jeweler’s rouge or something like that.
If the drive is nice 'n quiet, then you know it’s the outer works that is making all that racket. Good luck with that. [*-)]
Incidentally, for doing further superdetailing, there is a very interesting evolving thread on RyPN about the impending restoration to operation of the last surviving Climax A:
You will never get these to run quietly. No one, not even NWSL, makes a gear kit for this.
i have used a Bachmann 44 ton mechanism in place of the original Roundhouse / MDC drive. Takes a little work to make it look good, but is well worth it. Until the Bachmann gears split, that is!
Would a Bachmann 45 ton chassis fit? I would bet the siderod action from the Bachmann locomotive chassis on the Roundhouse Climax would be great together.
