Coloured Circles/dots on Freight Cars
Lately I have been spotting an increase in the use of coloured painted dots or circles on freight cars but have not been able to discover what the dots/circles mean.
Most of the dots/circles have been painted on autorack multilevel cars and painted on the second vertical exterior post just above the truck either at the A end or the B end it doesn’t seem to matter. A lot of older SOO Line boxcars have variations on the colours below as well.
Dot/circles so far have been: (1) red only (2) red over a blue rectangle on a yellow background (3) red dot on a yellow background (4) grey or white only (5) blue only (6) yellow only.
Does anyone know what these various coloured dots/circle signify? Are there more variations than the colours above?
Thanks, Rob
I looked in on this one because I was told that it “had my name written all over it.”
I have two things to say to that:
  1. Not guilty!
  2. Don’t know what these dots would be for; they’re probably a code understood by automobile manufacturers or loaders indicating possible uses or assignments.
More help might be forthcoming if I happen to notice a correlation between these dots and (1) types of auto rack or (2) colors in relation to certain manufacturers. Won’t be easy, since it’s difficult to see inside the racks.
Pictures would help a lot!
I can tell you this much , on Auto racks the dots on the side tell the loaders the minium deck hights inside the cars . I used to have a list of what each one means but I can’t seem to find it . The Dots on the doors tell the inspectors what up- grades to the doors have been done .
All of the dots have meaning but they are generally car type specific .
Anyone remember the yellow or white dotted freight car markings for trucks or wheelsets from the 80’s or 90’s? Southern Co?
Rix
Yup!
RE: those early dots, didn’t they have something to do with cast or wrought or however they make wheelsets today?
I think they had to be changed out or retired.
I can’t remember the exact details, Rick, but it had to do with a certain manufacture of wheels or axles that were suspected of causing a number of wrecks. The order was to change them out as quickly as possible, and inspect them right away. The circle was on a black square: if it was yellow, the wheels had been inspected and found to be all right. If it was white, they had to be changed out (working at a yard with a good-sized repair track, I don’t recall ever seeing a white dot).
These markings applied to 50-ton and 70-ton freight cars only (both of which used 33-inch wheels), but every once in a while you’d find a yellow dot on a stray 100-ton car. I’m pretty sure the whole episode was in the mid- to late 1970s, but of course the dots lasted on some of these cars well beyond that (you might still see one, if you’re lucky…and it had better be yellow!)
