Hello: I am wiring a small (~2’ x 13’) HO switching layout and currently have a separate power bus, using a 9v 300mA “wall wart”, to power 10 Tortoise switch machines. I will next be adding LED lighting to the scenery and was curious if the group would recommend running a power bus for the LEDs that is separate from the bus used for the switch motors, or if it would be ok to use the same bus.
I anticipate having around 150 small LEDs (“grain of sand” type bulbs or slightly larger). If a separate bus would be preferred, would another 9v 300mA bus do the trick?
Tortoise switch machines require ~10 ma. Modern LEDs may require < 5ma.
While a 300 ma wall wart would not be sufficient for 150 LEDs, there’s no reason you can have multiple wall warts, each proving power to some section of the layout. Each should be the same voltage.
while you could have separate supplied for the LEDs and switch machines, there’s really no need to have a single bus around the entire layout for just the switch machines.
I too prefer separate bus lines for separate purposes. I use 12 VDC lines because I like the warm look of incandescent bulbs. For a few LEDs I put in resistors. I also use this bus for my Miller Engineering advertising signs, again lowering the voltage with resistors. I also installed separate bus lines for streetlamps so I can turn those off separately.
I run power from a small separate supply directly to the control panel, and then power the Tortoise machines individually from there. I power twin-coil machines first through a Capacitive Discharge circuit and then the control panel. Each turnout gets its own cable. I use 4-conductor phone wire for that.yes, ther are extra wire, but having them neatly bundled in a cable is cheap.
I am a electronics professional of simple solutions. Simple solutions provide for simpler, cheaper and faster troubleshooting and repairs.
On my layouts I ALWAYS use just one common power source. There’s no reason or Use Case that cannot be resolved by using a single power source. In either DC or DCC mode.
