Hello, all. Hopefully there’s someone out there who can help me with a really confusing situation involving a Digitrax DB150 command station.
This used to work just fine- I could run trains, program, etc. Then, I made the mistake of trying to hook up the LocBuffer I recently completed. (Oh-ooh…) Nuttin- DecoderPro monitor didn’t see any action on the bus at all. Well, just to assure that the command station was still working right, I started by trying to program a loco (BLI E-7A) from the DT-400; what I would hoping for was at least seeing those commands on the bus. Still nothing, and more worrying was, the loco didn’t respond to the programming commands.
OK, take a step back. Disconnected the Locbuffer and tried the programming again- still no response. Tried to program another loco (DH-163-equipped C30-7). Still no response. Now I’m getting worried.
Put a THIRD loco on the track (this, a BLI SW-7) which had been previously programmed, and tried to just run the darned thing- still nothing.
Wiring problems? I switched over to DC (there’s a DPDT switch in-line), and had no problem running the two BLIs. Bad sign- sounds like there is some problem with the DB150.
OK, let’s step back further- all locos off the track, flip the DPDT switch back to the DCC side, and get out the VOM. I measure ~16VAC at each of the following locations: at the control station, at the command-station-side of the DPDT switch, at the track-side of the DPDT switch, at the quick-disconnect between the control portion and the track (this is a portable layout), and AT THE TRACK!!! Doesn’t look to be a wiring problem, and I’m getting the 16VAC, suggesting that at least the booster portion inside the command station is working.
NOW we get contradictory, though… try the “coin test”. Take one nice, clean US quarter, and put it across the track.
NUTTIN’. The command station SHOULD beep and fla***he warning light. Nope-nuttin.
Final hope- RTFM
