I’m curious to know if you can run 2 powered engines on one train as a consist easily in DC? I read in an old (1987) MR about the Utah Belt where Eric would hook his engines together with wire running between the engines. Is this a good way or is there a better way, or can you just put two locomotives on the same track and run them. I would especially like to run rngines back to back, if thats possible. Thanks for any help.
Yes you can. I have run three and four powered engines together with no problems. There are two points to keep in mind when doing this.First you must have a power pack that can handle it. Second, for best results, make sure that both engines have the same kind of motor in them.
Just because a power pack says it can run multiple trains doesn’t mean it’s always so. Example: running two “blue box” atherns requires more power than does running three Atlas engines or three Kato engines together. I know this because one of my power packs has an Ammeter and a voltmeter on it and I can see exactly how much power that the said engines draw vs the amount of power going into the track. If you’re not sure, then try running the two engines together. If you have a substantial reduction of power when you do this, than your power pack is too small. The second important point to keep in mind is to run engines that each have the same type of motor in them, otherwise one may work against each other. I have never used any wires between them.
My layout is powered using the old DC method. When I want to couple them together, I drive them both up to opposite sides of an electrical block on the track. I stop them both at the edge of their grids. I then shut off one grid, Then I ease the engine on the live grid up and couple up with the engine on the dead grid. I then flip the switch changing over to one power pack, turn the other grid back on and then take off with both engines.
This is fine - I’ve run consists of three powered locos with no problems. Best way to find out if the locos will run reasonably together is to put them on track, a little distance apart, and turn the power on. If they stay much the same distance apart they’ll be fine together. I usually put the faster loco behind as the train weight means that the couplers will be kept under tension throughout the train, and there will be less strain than if the lead loco is the faster one.
So what is a good powerpack for running multipe athearn engines? One of my accessory powerpacks blew and the Loco one is the same type, just a trainset powerpack, so I’m going to buy a good powerpack. I was thinking a MRC 240 or 260 powerpack, but whats really best?
One (or two) of the MRC Tech 4s would get the job done. Another good choice would be the MRC Trainpower6200 (60 VA), the ControlMaster20 (100 VA), or the Tech 3 Power Command 9500 (30 VA, probably more than enough). But, the power packs listed above may have to much power. Then again, you can never have to much power.[;)]
Some of the Kato units now have a warning on the carton"do not operate in access of 12 volts"
which I never caught until the latest uproar about the about the AC4400 board fryiny
Go to www.modelrec.com and click on train controls, then tech 4, which should display four models. Click on the picture for an exploded picture and details.
There are other models as well and you should be able to pick up a pack at 25% off thru Trainworld.
I run a matched Proto set of A-B-B-A FA-2’s off a Tech4 this throttle has the power to move em. This is probably going to be the biggest power I will run on the layout.
I will be doubleheading some small steam but the impact is minor compared the the proto units.
I do have a Athearn Cow and Calf from the late 80’s Both have power in them and I replace couplers between em regularly. Drawbars lift one power truck too high for traction at grades.
I have a Tech 3 Power command 9500 (30 VA), and a Sound n’ Power 7000. It has 30 VA on DC and 60 VA on AC. The variable AC on this is for running G scale, which I don’t use. I use both of these power packs on my layout. Among the engines I run are 2 Kato GP38s. I’ve never had a problem with them ever getting hot, but then it hardly takes any voltage to run them.
To get the full voltage that either of these two power packs have, one has to turn the trottle up all the way. The most I’ve ever had to turn the thottle up on either one of these packs is maybe between a fourth and a third of the way. But that’s only when I’m running four of my atherns together, as these draw a lot more power than do my Atlas or Kato engines. Years ago when I first got into the hobby, an old modeler once told me that an engine will only be as good as the power pack that is running it. He was right. I didn’t listen to him and had to learn it the hard way.
I run multi engines most of the time, sometimes even when just switching cars, as this is what I have observed the real railroads doing time and again. I used to have a problem with power packs getting hot. I would have to keep switching power packs to counter this. This restricted me from what I really wanted to do.
Now I don’t have to do that anymore. I can spend an afternoon moving cars around the yard and then dropping them off and picking others up at businesses along the line while using multi engines, and at the same time be running another multi engine frieght, or a two or three engine passenger train along a main line at a scaled 40-50 MPH on a continuous run and neither one of my power packs nor any of my engines will get hot. These power packs weren’t cheap, but darn it, I wanted something that would satisfy my needs, and these two do.
Be sure to have enough power when running MU on DC, the largest consist I ran was an P2K F-3 ABBBA set, ran ok but after 5 minutes it stalled, I cut the power ran a few feet and stalled, pulled out the track cleaner, nnothing, took of 2 B units, it ran OK, tested the other units, it ran OK, put together all 5 and it stalled again, [xx(]
It took me some time to realise that is was the thermal protection in my powerpack that kicked in when running 5 engines, after a few seconds the thing cooled down and reinstalled power.
I test if locomotives can run together by putting om track with a couple of inches between them, let them run, and watch the space between them, if the running speeds is allmost equal I couple them together.
BTW: in power I mean not the maximum volts the powerpack can give but the Amperes ( or VA )
I don’t have any literature on the P2K F3s but my P2K E7 draws approx .50 amps at the high end
of 14 volts. If I were to run five of those , my MRC tech 2-9500, 30 VA rating, would register 2.5 amps, darn near the 3. amp capacity.
What pack are you using for the five locos?
My P1K -F3 draws .25 amps. For my four F3 A-B sets totals out to be 2.00 amps, well under the
max of 3.0- capacity on my 9500.
I am using a Fleishmann 712 ( German 2 rail DC manufacturer ) powerpack rated at 28 VA ( 2A x 14V ), so that figures why after some time ( app. 5 minutes) the themal protection kicked in, and kept switching the power on and off afterwards.
Those five engines take about 2,5 A and the powerpack only is rated a 2 A
Thanks again to all of you. Now I’ve got to go power pack hunting (actually, I had to anyways) I’m going to try the local hobby shop and maybe Ebay, so wish me luck,
go for it Noah, the higher VA rating the better ! you might not be needing it right away,
but you won’t regret it later, when you want to add lighting and other energy consuming gadgets on your lay-out [8D]
