Converting 1959 Fleischmann and others from DC to DCC
First of all thanks to the group for allowing me to join! I have several H.O. scale brands of diecast steam engines from 1959 and later that I would like to convert from DC to DCC. I realize there may be some obstacals to overcome, but am willing to try such an endeavor. Could someone give me the pros and cons of this conversion if it is possible. The first locomotive is a 1959 Fleischmann steam engine 4-6-2 that was given to me in the 60’s as a Christmas gift. Over the years I have collected quite a few other diecast engines and recently have had the bug to enjoy my childhood toys once again after being in a box for 45 years. Any help in this process would be much appreciated.
The only real advice I can give is to test the locomotive on DC for amp draw. Then to make absolutely sure the motor brushes can be isolated from the track pickups/ frame.
There may be someone on the ESU Loksound forum that has done it or more familiar with it.
The only Fleischman trains I have is a crane with the support carriages and a DB diesel that never really ran too good but the lighting was ahead of it’s time. The first time I ran across micro LEDs, directional colored marker lights and a coreless motor.
Pete.
You need to determine how good the motor is, and you almost certainly need to isolate it from the frame. Older models often had very power-hungry motors that can actually burn out today’s decoders. There are often replacement motors available.
I too had trains from that timeframe, although mine were Athearn blue-box engines and had only sentimental value. They ran poorly after decades of storage, and would have required new motors, wheelsets and drive trains. But, it seems you have a better starting point than I did.
Mine were diesels, so I solved the sentimental problem by gutting the engines and turning them into dummies, some with lights, some with sound, to run them in consists as “honorary” engines.
Restoring old engines to operation is a noble endeavor.
I’ve upgraded a few older engines for sentimental reasons. The first thing to check is it’s performance. It should run well in DC before getting into DCC.
The second step, as mentioned above, is to test the amp draw. If it’s above 1 amp, I would say change the motor, but there are alternatives. Posting a picture of the motor would help. Do you expect to use this engine for serious operations? Or just get it running on a pike for fun from time to time?
In my humble opinion, using an older engine for serious operations is doable, but should involve a remotoring. Older motors just cannot provide good, slow, motor control. But that’s not an issue if you just want to run the thing around a track from time to time…
Simon
Out of 16 steam engines, 7 of the black diecast are in excellent running condition. Mantua, Fleischmann, Gilbert, Roundhouse and a couple of unbranded ones. I will take into consideration of finding out the amp draw to each of them. That is not something I thought of. Thank you for that information. I did have an idea that the motors may need be changed in them along with body ground isolation. My guess is that they would perform better and be more efficient with new motors vs the originals. No description available.
Let’s see pictures of the internal workings.
I’ve never done Fleischmann myself.
Hello All,
As Albert Einstein has been quoted saying,
“Once you open a can of worms the only way to get all the worms back in the can is to use a bigger can.”
I agree with all the replies to your post.
My question is, have you done a DC to DCC conversion before?
With engines that old a fair amount of soldering will be necessary.
Many older DC engines picked up power from the rails in several different configurations compared to modern locomotives.
Some had offset pickup; the locomotive’s wheels would pick up power from one rail while the tender picked up power from the other rail.
This means the tender has to be electrically “connected” to the motor in the locomotive.
While others used the frame of either the locomotive or the tender as an electrical path to the motor.
In this situation, you will need to isolate the motor from the frame and possibly add wheel wipers (contacts) bypassing the frame as an electrical conductor entirely.
As has been posted, the OEM motors might pull too much amperage for DCC decoders- -even “larger scale” decoders, that can handle higher amperages.
Older open frame motors can be “rebuilt” by replacing the older Alnico (iron) magnets with rare-earth magnets.
If not you will need to upgrade to a modern motor.
This might involve fitting a new worm gear from the motor shaft to the gearing in said locomotive.
So…
You have isolated the motor from the frame, added wheel wipers for better electrical pick up, rebuilt the old motor with rare-earth magnets or replace the motor with the proper worm gear to match OEM gears in the drive train, then tested it in DC to make sure the new components work, now you are ready to install the DCC decoder.
We haven’t even discussed adding sound…
Now you have to d
If it’s this model:
https://www.ebay.com.my/itm/Vintage-Fleischmann-HO-Scale-4-6-2-Locomotive-Loco-Engine-1366-/293016443041
It appears that this is a multiple gear-driven loco. Looking at it from behind, it looks like some kind of flat motor. I think you are getting into quite the challenge, if this is the loco in question. Apart from the amp draw, the motor needs to be isolated from the frame. If my guess is right, it will be quite difficult to do with this engine. And if the gears are out of whack, fixing that may be a major challenge in itself.
Simon
The motor in Simon’s example looks very similar to the one here:
https://tcsdcc.com/installation/ho-scale/1274
except that it’s in the tender. Being in the engine, the wiring is likely designed differently, but it looks doable. Of note is that they want the RF choke removed, so that should be done. I also see a comment “Cut link”. That looks suspiciously like the connection to the frame. But, again, the motor’s in a different place.
I think you’ll have to make a wiring diagram, and then decide what wires to cut and/or solder. Yup, looks like some soldering there.
Anyway. It looks far from impossible.
Ed
Edward Sutorik
After reading all of the very informative posts on my question to convert the old dc to dcc, it seems that I should just leave these engines alone and look more towards investing in dcc ready ones. I surely do not want to open up a can of worms that might or might not work and possibly ruining any of these engines that I’ve had since a young age. With my planned layout I do believe I will need to have dcc instead of a dc setup. With all of the dcc controller choices out there how can one know which system is good, bad or otherwise?
Hi,
I have remotored all my Fleischmann locomotives before converting them to DCC, they were a great inspiration for me due to their high overall quality. Only the motor is rather old technology and gears often sound like a coffee grinder, so I decided either to replace just the motor with appropriate coreless replacement (available on Aliexpress - 7 mm or 10 mm thick), or to make new gearbox and install coreless can motor. The second option is much more extensive but provides virtually silent running.
Below are few examples of both approaches.
New motor only for BR 38 (involves cutting part of original frame and gears):
Old motor removed
!https://up.picr.de/40035962uu.jpg?rand=1639549727
New motor ready, part of chassis cut, motor holder glued
!https://up.picr.de/40035964le.jpg?rand=1639549727
Mot
Hi,
Fleischmann motor cover design changed over decades, but principle was always the same. Older covers do not isolate brush holder from frame, and in older motors it is sometimes impossile to modify motor cover (German: motorschild) in a way that brush holder is isloated from a frame. In such cases, to keep old motor, new motor cover shall be installed.
Here is an overview of many different Fleischmann motor covers, some of them can be “converted”, some not. In left column original “DCC not compatible” covers are shown. In middle column covers are shown whcih can be converted by cutting part of PCB. In right column only DCC compatible covers are shown.
This web site is in German, but offers many pictures with examples how to convert older Fleischmann locomotives to DCC without replacing the whole motor, so foreign language is not a problem, pictures are in m
I would suggest a separate post for this - then sit back and watch the fun[:)]
There are a couple of very good systems out there and each has it’s benefits - and fans. If you have a local club, or mrr friends, ask what they use. If you can look at units at a hobby shop, hold them - which feels better in your hand? Which seems easier. I have the NCE starter system and it works for me but you may want something different.
