Converting Roundhouse Box Cab to DCC?
I just finished assembling a Roundhouse HO Box Cab Diesel kit and it has an unusual drive system. I have a can motor that is almost a perfect replacment for the open frame one that came with it. My question is; has anyone converted one of these to DCC and does it have any issues I need to be aware of. The engine uses the chassis for power to one of the motor leads and the other is through the insulated truck mounting, I think? This is a very noisey engine and I think it is in the gearing and not the motor so I don’t think it will get much quieter with DCC or a can motor, but if I want to run it on my layout it needsto be DCC. I also plan to put some LED’s in. Any comments or suggestions will be greatly appreciated.
-Bob
If you don’t know how the power is picked up from the wheels by visual inspection of the assembly diagram, you need to get a cheap digital multimeter so you can trace the wiring. Harbor Freight sometimes has them on sale for as little as $1.98 or $2.98.
Most of the noise from those old Roundhouse models was a combination of the cheap open frame motor being screwed down directly to the frame, and gears with lots of burrs on them.
On the Boxcab, the frame is one side of the rail pickup, and that brass bar along one side is the other (hence the plastic bushings in the screw holes for it). If you repalce the stock motor with a can motor that has two wires, such that neither brush is connected to the motor’s case, this will work fine. If you have the version with the flywheel, tha flywheel is next to useless, so you could remove that and have a ton of room for a decoder. At one time I believe NWSL made gears for them to replace the not so good plastic ones that are extremely noisy, but I don’t know if they still have that. Unless you revamp the entire drive I wouldn;t bother with sound, the noise of the mechanism will overwhelm the sound decoder. They do run nice and slow, just loud.
Bob:
I had one of these and replaced the original motor with a can motor and converted it to DCC. I can’t remember what decoder but there is plenty of room. The drive is noisy especially going around curves. I tried replacing the gear that drives the large “bull gear” but that didn’t help. There is also a contact issue with the pickups from the trucks. You need to keep the area where they rub on the frame contacts very clean or the performance suffers. I liked the loco and it performed reasonably well until it took a fatal plunge to the concrete. I still have the p[eces and may try to resurrect it one day.
Joe
Randy,
The can motor has isolated contacts so it should work as you suggested. I already canned the flywheel??, it would have worn out the plastic bushing in a week and nothing was balanced. I was hoping to detail the cab interior at that end (where the flywheel was). It also looks like an easy loco to add LED’s. Thanks guys for all the good comments.
-Bob
I had one when I was a kid, the early versions did not have the flywheel. At full throttle is used to never go more than 15-20 smph, until one day is just sort of took off and flew off the end of the layout. I still have most of the pieces of that one. I bought anohter one later on which I was planning to paint for some road or other, I never did get that far. I did paint the interior with that generic institutional green color that was widely used for such things. One of the truck retainers broke on it, and it’s packed away somewhere as well. I think between the two I can make one good one.
The first one was in the Ingersoll-Rand scheme, my grandfather worked at the plant where they used one as a plant switcher. Somewhere although I haven’t sen it in years, is some information he managed to get when they had a ceremony retiring the unit. I’ve alwyas loved boxcabs liek that, and the Reading did have 2 of them, one of which was the second one ever built. Both were retired and/or scrapped by the era I model, but on my version, one will still exist. I’ll either fix up/modify the Roundhouse one or try to find one like Tim Warris has for his CNJ Bronx Terminal layout - I think it’s a brass model, it runs VERY quietly and smoothly.
One thing that you can do with the pickups is to solder wires to the wipers on top of the trucks. On the brass bar side, you can probably runt he wires up through the holes used to mount the brass bar and the screw on the bottom that the truck wipers rub on, on the other side it might be hardeer, drilling that soft metal can be difficult, you need to go slowly and back out frequently to clear the chips or you will break the drill bit. Some oil for lubricant wouldn;t hurt either. This way contact would no longer be dependent on a brass wiper that can get dirty rubbing on a screw head.
Quite easy. Red wire to insulated brass strip and black wire to frame of loco. An old Digitrax decoder.
Did almost the same with a MDC Climax with Micro Tsunami sound.
One thing that I have heard is that the Bachmann 44 ton chassis is almost a direct replacement for the box cab and the climax by Roundhouse. (Both use the same frame and drive system.) You might want to checkout the truck spacing just to make sure. That would eliminate a lot of issues with the nosy drive.
Rich: what motor and drive gears are in that Climax? They might also work in the Boxcab, since it’s essentially the same chassis and drive. I have an old issue of Railroad Modeler where they introduced the Climax as a kitbash of the boxcab, and also showed a few other bashes that never made production.
Elmer: I don’t know that it’s a direct drop in, with no work involved, but it seems to be easy to do. However, the 44 tonner sideframes are wrong. The Roundhouse ones really do look like the proper type, the 44 tonner ones are a newer style. I know, picky, I suppose.
Rich,
Same question as Randy: What motor and gear are you using? Looks like a nice setup. My can motor looks a lot like the one you have, but I only paid $5 for it on Ebay a few years ago (just in case I might need one?), so it probably isn’t the same one. I have a spare 44 tonner that I will check into tomorrow and see how close it comes to fitting. These are some great ideas, keep them coming, I might find one that ‘fits inside the box’ so to speak.
I put some NYC decals on mine today and started a cab interior. I also plan to use the typical green interior cab color which I did on my Athearn Hustlers.
I have a few NCE basic decoders that I am sure will do the job here.
-Bob
Hi everyone,
I’m new to remotering and rebuilding and my first project is the Roundhouse Climax (HO). I have successfully installed an LED and a decoder but I want to replace the open frame motor.
Can anyone tell me what motor to use and where these motors can be obtained?
Thanks
Ed
The person I got the parts from is gone from the Internet becasue of health reasons. He published a book with details but I have to find it. Below is the motor, flywheel and gear. I think the gear and flywheel are from NWSL but I have to find the book.
I saved his website as an HTML document for the below data.,
OPTION #5 - PRECISION CAN-MOTOR FF-180PH - $10.OO PLU4.55 SHIPPING
MOTOR WITH FLYWHEETL AND BRASS 26 TOOTH
All motors are new, not used. Motor running at full throttle when power is shut off, will take 2-3 seconds to coast to a stop.
You might try a Internet search for Ron LaFever Climax book.
A question to Dave at NWSL about possibly this guy ordering from him might help.
I don’t think those are NWSL products, or if they are, they don;t have anythign anymore. The current catalog lists, under the ROundhouse CLimax/Boxcab section, that these locos cannot be economically re-geared - which makes no sense to me, unless I am missing somethign it’s a matter of making a better quality gear inthe same size, and they have TONS of different size gears they already make. At any rate, the only kits they have are for the Shay, and it appears that the Shay is vastly different than the Climax/Boxcab even though they all drive from the center in much the same fashion.
I do know NWSL has nothing specific but Ron might have found something there that worked. At any rate, when I get home I will see if I can find the book he wrote for the specifics.
The motor runs very well but I was surprised at the price. I have seen similar motors on ebay once in a while.
A lot of fine tuning in each truck is needed as well as #30 wires instead of the metal clips used on each truck.
The frame had to be shaved.
The plastic shells transfer any vibration quite well.
A site called, Two Guyz and Some Trains had a very good article using a drive belt anf two pulleys instead of the gears but the site is gone.
Can always fall back on what Geared Steam did.
http://gearedsteam.blogspot.com/2009/09/mdc-boxcab.html
Actually, NWSL even says the stock motor doesn’t have to be repalced - it’s an open fram Sagami what runs well. It’s the gears and drive that are noisy.
Yeah, the 44-ton repalcement is definitely one way to go, but as I mentioned, the truck sideframes and the wheelbase are off. Doesn’t really matter for the Climax since half of those were built up from what seems to be spare parts anyway. If you’re not picky, it’s probably close enough for the boxcab.
The original open frame motor and flywheel in the boxcab photos does not run as well as the Climax with can motor and flywheel. Each end of flywheel shaft in the original adds a little friction and noise. The original fly wheel is kind of a rough casting and wobbulates a little in the plastic support for each end of the flywheel.
Roughly simulates the sound of a noisy diesel when run on our DCC club layout as it has the track cleaner pads.
Guys,
Thanks for all the quick replies. I have the Climax running on the club’s DCC layout and I’ve added an LED headlight. The noise of the unit is quite distracting, especially since it makes adding sound not feasable.
I’ve spoken to NWSL and he said that he might work on a repowering/regearing unit for the Roundhouse Boxcab/Climax and to watch for its release. When? Who knows. He told me that the current option that combines various available parts, would be too difficult for a novice. Meanwhile, I wanted to add a can motor while I was waiting for regearing but I’m inclimed to agree with the poster who blames the noise on the plastic gears and frame rather than the open frame motor.
BTW, the unit looks dynamite repainted in black and earth (does a decent job resembling wood). With the LED and the DCC installed, the unit looks much better than it sounds or runs.
I hope that NWSL actually makes a regearing/remotoring kit. If others are insterested, I suggest that you make it known to NWSL. I have 2 other units ready to be reworked.
Thanks.
Ed
Well the 44 tonner is a little longer on the wheelbase and as Randy said, the sideframes arent’ the same. So far mine is running quite well although a little noisey and it almost sounds like a diesel. I think I will just try a decoder for now and if that works OK I will leave the motor as is. The photo of the can motor with gear and flywheel looks exactly like the can motor I have, so that may not be a difficult job if I decide to replace it.
I am really grateful to all you guys for the input on this. At least I know this little engine has had some serious rework done by others. I will post some pics when I get it done and when I get a new camera! (mine just won’t work anymore, apparently I got some sand in the lens mechanism at the beach earlier this year and it is jammed.).
-Bob
Change the 44 ton side frames to the MDC side frames, I preferred to have an operating loco vs a poorly running blender for twice the price. but good luck to you, I did much research on this prior to making my decision, even talked several times to LaFever,in the end, I went with the modern approach, no one ever notices the side frames, or cares that much, paint and weathering will help
